[Z06] 2002 zo6
Old Aug 7, 2009 | 01:03 PM
Popclutch's Avatar
Popclutch
Default 2002 zo6
Ok, heres the deal. I have an '02 ZO6 that just quit while coming home from work (check previous post for more details) and since losing my job I don't have the cash to just get a correct diagnosis on what the problem may be. The engine code reads as "engine misfire". My understanding is that a good code scanner can detail this even further and will give me a better idea of what the problem is. I have never had to ask for help from anyone in the past, but my economic situation forces this request.
If anyone locally (Orlando,FL) has a scanner that could help me narrow down the problem and would be willing to help me figure this out, (I'm not asking anyone to actually FIX the car, just looking for what the problem may be) it would be GREATLY appreciated. Thanks for reading this thread.
Pop.
Old Aug 7, 2009 | 10:20 PM
hammert85's Avatar
hammert85
Did you check your plug wires??? Maybe one is loose or melted? Do you have aftermarket headers? Good luck.
Old Aug 7, 2009 | 10:51 PM
USA1 427's Avatar
USA1 427
Contact JJFormato
Jeremy Formato. He's a supporting vendor on here and is in Tampa. He's about the best at tuning Vettes.
Old Aug 10, 2009 | 08:36 PM
Popclutch's Avatar
Popclutch
Originally Posted by Z06RL
Contact JJFormato
Thanks to You guys who took the time to reply! Checked the obvious and found nothing with the plugs, wires or that "hidden" ground wire attached at the rear side of the drivers head. All appears to be normal.
Thanks again,
Pop.
Old Aug 10, 2009 | 08:41 PM
03SlowZ06's Avatar
03SlowZ06
Pop. If you have no luck by this weekend I can come down and scan the car for you. I am in Jax right now for school.
Old Aug 11, 2009 | 01:08 PM
TK6's Avatar
TK6
I would get the valve covers off and check for a broken valve spring. Just my $.02.
Old Aug 11, 2009 | 01:56 PM
James92's Avatar
James92
I had a couple bad coils cause a temporary misfire for me. Does the car run at all?
To 2002 zo6
