Switchback LED brightness?
Old Aug 9, 2009 | 05:14 PM
CUlookin's Avatar
CUlookin
Default Switchback LED brightness?
Hey guys, just got back from vacation and had my Switchback LED's waiting for me. Spent about 30 minutes installing them along with a new flasher relay and went to test them out. They worked perfectly except the running light is not as bright as the old orange bulbs I had in there. The switchbacks are 60 LED stalks running in clear corners. Any thoughts? Thanks in advance.
Old Aug 9, 2009 | 06:14 PM
jdmvette's Avatar
jdmvette
Night Owl for life
hmmm...my switchbacks are very bright. did you try reversing them in the socket?
Old Aug 10, 2009 | 02:31 AM
AUandAG's Avatar
AUandAG
I agree with you CU. I installed the same hardware a couple of weeks ago.I think they look great, but the DRL's are not nearly as bright as I expected and are nowhere near as bright as stock bulbs.
jdmvette...the 60 led switchbacks can only go in one way and function properly.
Old Aug 10, 2009 | 06:14 AM
jdmvette's Avatar
jdmvette
Night Owl for life
well ive got the 48s and they're seriously bright in my clear corners.
Old Aug 10, 2009 | 08:35 AM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
My switchbacks in my clear corners are quite bright
Old Aug 10, 2009 | 09:12 AM
CUlookin's Avatar
CUlookin
AUandAG's right, they only work one way.
I'm glad to know I'm not the only one.
Thanks for the pic, that's about how bright my DRL's are. The running light are not quite as bright. I'll be sure to post some pics this evening for comparison.
Old Aug 10, 2009 | 09:14 AM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
Those look great. Where did you get them?
Old Aug 10, 2009 | 12:29 PM
Toque's Avatar
Toque
autolumination dot com ....
Old Aug 10, 2009 | 12:53 PM
Tech's Avatar
Tech
My 60-led switchbacks aren't anywhere near as bright as the factory bulbs during the day. I was disappointed when I realized it.
Old Aug 10, 2009 | 01:09 PM
tbrent's Avatar
tbrent
2018 C5 of Year Winner
When the switchbacks go to running lights it DOES seem that at some angles they seem a bit more dim. Of course that's only during day light hours without overcast. Could also be because of the lense with no bends in it to help spread the light more. Jason, you have the corners with the bends in the lense right? When should we expect new lighting mods btw Dad.
Think I need to upgrade to the 60 led tower. WOOT WOOT
Old Aug 10, 2009 | 01:56 PM
Tech's Avatar
Tech
[edit]There are two Jason's in this thread. [/edit]
Old Aug 10, 2009 | 04:54 PM
romeokc10's Avatar
romeokc10
There's a thread where a lot of guys are having problems with the 60 LED swichbacks, I'm going with the 48 LED.
Old Aug 10, 2009 | 05:09 PM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
An LED in a stock housing isn't going to produce a brighter light. The main purpose is for a better looking light. That's why we don't advertise them as brighter. We call them an enhancement. They also run cooler than stock which tends to burn through the DRLs.
Some think they are brighter and some don't.
Now they should be bright enough where you can see them.
That 60 bulb is from the non supporting vendor listed above.
Besides from a few DOAs (which we replace) my 60 version has been great. We use different types of bulbs than the other guys.
Old Aug 10, 2009 | 05:19 PM
Tech's Avatar
Tech
FWIW, mine is in the same housings pictured above. Clear/amber with black accent.
Old Aug 10, 2009 | 05:30 PM
romeokc10's Avatar
romeokc10
Hey Jhonathan_W good too see you're on the site, I just bought aftermarket corners that are clear and amber. I want the 60 LED bulb, which bulb do I get for the 194 size bulb from your site?
Old Aug 10, 2009 | 05:52 PM
JW Motorsports
Banned Scam/Spammer
Either the white or amber. Your reflectors are amber so it really doesn't matter.
My switchbacks are out for about 1 week though. I can't keep the things in stock.
Old Aug 10, 2009 | 05:57 PM
romeokc10's Avatar
romeokc10
no problem, what about the harness to prevent hyperflash?
Old Aug 10, 2009 | 06:00 PM
JW Motorsports
Banned Scam/Spammer
I'll Pm you!
Old Aug 10, 2009 | 06:08 PM
AUandAG's Avatar
AUandAG
Okay...Here are photos I just took. These are the 60 LED switchbacks from Jhonathan in new clear (ribbed) corners w/amber sides. Don't misunderstand...I think they look great! But I wouldn't call them bright either. Actually, I think they look brighter in the photos than in person.
The last photo was taken inside the garage. All others are outdoors in full sun.
To Switchback LED brightness?
