Shifter Knob Removal
Old Aug 11, 2009 | 01:36 AM
knite's Avatar
knite
5th Gear
Default Shifter **** Removal
I just recently bought my 01 vette. I have an after market shifter **** i want to install but I cant seem to get the stock **** to unscrew. Is there a special way of me removing it? I dont want to try to force it off by unscrewing it. Thanx for your help!
Old Aug 11, 2009 | 02:28 AM
Dave68's Avatar
Dave68
Default Demon pin removal unmasked!
Yes, there is a distinct way to remove it and here it is:
http://www.conceptualpolymer.com/corvette_install.htm
Old Aug 11, 2009 | 02:31 AM
knite's Avatar
knite
5th Gear
Thank you very much. I appreciate the step by step pics too. You rock!
Old Aug 11, 2009 | 03:10 AM
WildTurkey's Avatar
WildTurkey
Hmmmm - this looks different than mine (2000 A4 vert). If I recall, my "key" looked like a big staple and went in horizontally at the base of the top part of the ****. Once you removed the "key" (I pried out mine with vice grips), the **** popped right off.
Old Aug 11, 2009 | 04:14 AM
Eric the Ricer's Avatar
Eric the Ricer
From: Beyonce > Taylor Swift - Welcome to the good life!
St. Jude Donor '07
I hate that freaking key
Old Aug 11, 2009 | 05:38 AM
Hammer99's Avatar
Hammer99
I used a paint can top remover. Get it under the forward (toward dash) corners and pop it out in 10 seconds!
Old Aug 11, 2009 | 10:09 AM
TEXHAWK0's Avatar
TEXHAWK0
It does help if you give as many details as possible when you ask a question. We assume you have a manual transmission, but neither your question nor your profile says that.
Old Aug 11, 2009 | 11:15 AM
homewrecker's Avatar
homewrecker
Demons!!!
Old Aug 11, 2009 | 11:55 AM
hotwheels57's Avatar
hotwheels57
Manual has "demon key"...automatic has a staple.
Old Aug 11, 2009 | 02:11 PM
Using the method in the link above the key should pop right out. It worked like a charm when I did mine.
Old Aug 11, 2009 | 07:13 PM
rws.1's Avatar
rws.1
Old Aug 12, 2009 | 02:24 AM
mosimann's Avatar
mosimann
It took me at least 10 minutes to take it off.
To Shifter Knob Removal
