Please Don’t Laugh At Me.
Old Aug 13, 2009 | 05:41 PM
Ohdee's Avatar
Ohdee
Default Please Don’t Laugh At Me.
I have a c5 vert, four speed auto. I have what just may be the stupidest question in the history of the boards. I’m not sure which gear to drive in when I’m not exceeding speeds of 30/35 mph. When just casually driving around the city (no freeway) should I put the car in 3rd or should I use 4th/overdrive?
Told ya it was a stupid question!
Old Aug 13, 2009 | 05:45 PM
JimZRyd's Avatar
JimZRyd
St. Jude Donor '12
I use 3rd mainly..only feel the need for 4th/od on the interstate.
Old Aug 13, 2009 | 05:48 PM
road pilot's Avatar
road pilot
2016 C5 of Year Finalist
Sounds good to me. And I didn't laugh!!!!!
Old Aug 13, 2009 | 05:49 PM
Munch's Avatar
Munch
St. Jude Donor '10
I just leave it in drive.
Old Aug 13, 2009 | 05:50 PM
bstone1989's Avatar
bstone1989
you can select the gear your in, in the autos? never knew that..
Ohdee's Avatar
Ohdee
Old Aug 13, 2009 | 05:51 PM
stingraymyway's Avatar
stingraymyway
From: Out of Site...Out of Mind. Corvette: anything else is just transportation.
St. Jude Donor '09 thru '20
I just leave mine in D. Only use the lower gears if decending a long hill, I live in the Mtns., in order to not have to stay on the brakes.
BTW, only stupid question is the one not asked and you have to pay for the repairs.
Old Aug 13, 2009 | 05:54 PM
94-vette's Avatar
94-vette
Ohdee's Avatar
Ohdee
I had a friend tell me to always use 3rd unless I'm on the interstate/highway. I wasn't sure what to do. So if I just use D/OD I won't damage anything? If that's the case I'll just use D.
Old Aug 13, 2009 | 05:55 PM
Ohdee's Avatar
Ohdee
Originally Posted by 94-vette
Old Aug 13, 2009 | 06:11 PM
VinnyT's Avatar
VinnyT
I use 3rd in town and it wasn't a stupid question.
Old Aug 13, 2009 | 06:14 PM
Carlos Arredondo's Avatar
Carlos Arredondo
I have an 04 auto and around town keeping it in 3rd seems to be a nice gear and you can down shift into 2nd and or 1st without hitting the button on top of the shifter. Doesn't seem to be hurting anything so far. Hell, when I'm out on a fun run, I down shift to 2nd as long as my speed is under 55mph entering a corner. That puts my tach at about 3000 RPMs and then throttle through and out ,then tap the shifter up to 3rd as the revs build. The computer controls everything so there is slim chance of over reving unless you for get to upshift. My car is stock and alot of fun when opened up every once and a while.
Old Aug 13, 2009 | 06:20 PM
Dominic Toretto's Avatar
Dominic Toretto
Here's a better question. Which gear is better for the transmission?
-Alex
Old Aug 13, 2009 | 06:21 PM
oyealiz's Avatar
oyealiz
2022 C8 of the Year Finalist - Unmodified
CI 3-4-5-6-7-8-9-10 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'16
You have an auto. Put it in drive and forget it.
If you want to shift, get a stick.
Geez.
Old Aug 13, 2009 | 06:22 PM
oyealiz's Avatar
oyealiz
Why do you do this? Just to mess around? If you wanted to shift, why didn't you get a stick?
Serious.
I don't get it!
Old Aug 13, 2009 | 06:24 PM
rebelheart's Avatar
rebelheart
There have been several threads about how driving around town in 3rd can cause heat build up in an A4.Your computer knows better than you,put it in drive and let the computer decide.
Old Aug 13, 2009 | 06:26 PM
oyealiz's Avatar
oyealiz
My point exactly. Unless your dragracing or in some extreme climbing conditions, why the heck would you mess with your auto transmission yourself?
To Please Don’t Laugh At Me.
Old Aug 13, 2009 | 06:46 PM
jrose7004's Avatar
jrose7004
Old Aug 13, 2009 | 07:14 PM
dougbfresh's Avatar
dougbfresh
Did you ever think to READ you owners manual? In the early days of Automatic OD, the circumstances to shift into OD was CRUDE. You would end up in OD too soon many times bogging the vehicle. Many would say in the OWNERS MANUAL to leave it out of OD in city driving and into OD on the road. My Ford PU has a button just to engage/disengage OD without moving the Shift Lever. There are also hilly roads that can make the OD kick in/out alot, that would be another case you might want to disable OD.
RTFM (Read The Fxxx Manual) Use the F word of your choice.
Old Aug 13, 2009 | 07:18 PM
JimZRyd's Avatar
JimZRyd
St. Jude Donor '12
Your point has been made man.
Geez.
