Turn Signal Fix??
Old Aug 17, 2009 | 01:20 PM
85alusion's Avatar
85alusion
Default Turn Signal Fix??
Sometimes on my 2000 the turn signals fail to work. If I poke the emergency flasher button several times it will fix the problem for a short time. Any perm. fix for this?
Old Aug 17, 2009 | 01:30 PM
lil vette's Avatar
lil vette
http://www.adaptiveperformance.com/hyper.htm
Old Aug 17, 2009 | 01:39 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Sounds like your flasher is going bad. The flasher itself is located just behind the hazard switch. You'll need to replace it.
Old Aug 17, 2009 | 07:40 PM
Patches's Avatar
Patches
Check out all the links in this thread:
http://forums.corvetteforum.com/c5-t...l-problem.html
To Turn Signal Fix??
