Tree Sap
Old Aug 18, 2009 | 07:33 AM
hlf's Avatar
hlf
4th Gear
Default Tree Sap
Sap from some trees has fallen on the car and hardened like a rock. Any suggestions on best way to get it off?
Old Aug 18, 2009 | 08:00 AM
Some WD-40 should soften it up. Goo-Gone also might work.
Old Aug 18, 2009 | 08:08 AM
MyOwn69's Avatar
MyOwn69
Old Aug 18, 2009 | 08:15 AM
KenShores's Avatar
KenShores
Goo Gone has worked for me on mini van. It's no fun at all getting this off once it has hardened. I use my fingernail until I get most off without hurting paint, then the goo gone stuff. I've had pine sap on my mini van and it is a POA. Just take your time.
Old Aug 18, 2009 | 08:42 AM
SaberD's Avatar
SaberD
if you heat it up a little with a hair dryer to soften it and then use goo gone it may be easier. or get a can of duster and hold it upside down and spray the ice on the sap to freeze it. then it might chip off.
Old Aug 18, 2009 | 08:46 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
You can also use a plastic credit card after letting it soak in either of these. Then clay bar it and polish. Start with something that has a little corrective property and go to a progressively finer polish. Good luck
Old Aug 18, 2009 | 08:48 AM
03whitecoupe's Avatar
03whitecoupe
I have the same problem where I live. We have dozens of pine trees and I have to deal with the sap occasionally. I use alcohol wipes to get the sap off, but unforunately it also gets the wax off so I end up re-waxing the area. It's nasty stuff but it usually melts right off with the wipes.
Old Aug 18, 2009 | 09:03 AM
steve8's Avatar
steve8
You can try wd-40 or a clay bar, but I am a HUGE fan of stoners tarminator.
Old Aug 18, 2009 | 09:11 AM
jrose7004's Avatar
jrose7004
Those are the 2 things I use.
Old Aug 18, 2009 | 09:13 AM
02MillenniumVette's Avatar
02MillenniumVette
And if its on your windows Rain X will take it off of there.
Old Aug 18, 2009 | 10:58 AM
kg54trains's Avatar
kg54trains
3M makes a product that is available at retail auto part stores. It is used to removed wax, adhevises, stickers, etc. It works great and it is safe on your paint finish.
Old Aug 18, 2009 | 01:00 PM
INTRUBL's Avatar
INTRUBL
Visit a body shop and ask for some paint reducer, the stuff will work on sap and is finish friendly, but don't get it on your skin.
Old Aug 18, 2009 | 01:45 PM
Black04Z06's Avatar
Black04Z06
Old Aug 18, 2009 | 02:11 PM
hotwheels57's Avatar
hotwheels57
On the main menu page, scroll down to the Detailing Forum for more responses.
If you decide to use something other than WD40, heat, GOO GONE (safe to paint products), make sure you try it on an inconspicuous area first to confirm it won't harm your base coat/clear coat...
Old Aug 18, 2009 | 04:01 PM
bucwheat's Avatar
bucwheat
I agree with the freezing if nothing else works,I have had good luck with pre softened wax,but be persistent.
Old Aug 19, 2009 | 02:30 AM
striper's Avatar
striper
I've found that in most cases plain cold water usually gets it right off. If it's a little difficult, careful rubbing will soften it and get it off. The thing to be most careful about is using something that won't scratch the paint, like a microfiber towel.
Old Aug 19, 2009 | 03:10 AM
C5lady's Avatar
C5lady
I had tiny spots of sap or pitch on the left rear fender that had dried on. Clay bar took them right off but they had stained the clear coat so I polished it with the DA and the least abrasive level of polish and it's as if the sap was never there. Viala.
I like the idea of freezing it so it will pop off easier and then clay bar. I'll have to remember that if I encounter the problem again and can get to it before it dries.
To Tree Sap
Old Aug 19, 2009 | 04:17 AM
JETZ's Avatar
JETZ
Rubbing alcohol works like magic!
Use a Qtip soaked with it on the problem area, then I wipe down with a wet towel, or sponge, dry, then a quick shot of detail wax...good to go.
Even old nasty stuff comes off right away!
Frank
Old Aug 19, 2009 | 05:09 AM
tbaker1964's Avatar
tbaker1964
Wd-40!
Old Aug 19, 2009 | 07:27 AM
Tom/99's Avatar
Tom/99
Mineral spirits should remove it.
