Abs
Old Aug 18, 2009 | 01:18 PM
esh3323's Avatar
esh3323
Default Abs
i have a 02 c5 vert with 25K miles on it all stock...question is has anyone on here experienced a abs/traction control service warning and if so is it an easy or cheap fix? lastly will a heltech air intake along with borla stinger cat back exhaust help much with power gain,,, any suggestions i would appreciate thanks.
Old Aug 18, 2009 | 01:50 PM
knyght4's Avatar
knyght4
What's the warning say?
Old Aug 18, 2009 | 01:59 PM
esh3323's Avatar
esh3323
First thanks for quick response...it says service abs traction control system...1hen I restarted the car it was gone any suggestions on what to do
Old Aug 18, 2009 | 02:02 PM
dougbfresh's Avatar
dougbfresh
Post the codes (if you don't know how to do that, use the SEARCH function to find out how). Then post them here.
Old Aug 18, 2009 | 06:53 PM
02MillenniumVette's Avatar
02MillenniumVette
No its not a cheap fix if you have to replace the ABS computer, which is what I had to do. It was a $1300 fix. There are some places that have rebuilt ABS computers that would make it cheaper than that. You might not have to replace the computer though. If the message came up when you had the steering wheel all the way to one side and were moving, the the sensors might of been pulled on and it will send that message. I still get the message sometimes if im turning real sharp.
Old Aug 18, 2009 | 06:55 PM
JPM@AutoBuffs's Avatar
0JPM@AutoBuffs
Former Vendor
From: The AutoBuffs Army is unmatched in the Custom world! www.autobuffs.net
S. Jersey Events Coordinator
St. Jude Donor '08-'09-'10
Cruise-In IX Veteran
Damn..I thought this was a workout thread
Old Aug 18, 2009 | 07:15 PM
02MillenniumVette
Old Aug 18, 2009 | 07:22 PM
rws.1's Avatar
rws.1
It could be as simple as a loose connector at one of the wheels, that why the codes are so important.
IF it is the ABS unit, then www.absfixer.com will do it for about $300 and there is a forum member I saw a while ago that will fix it for $99.
Do an advanced search on ABS repair
Old Aug 18, 2009 | 11:52 PM
jrose7004's Avatar
jrose7004
I guess that it is in a way.
To Abs
