I replaced the stock nylon gears for the headlight motor, as one of the headlights was making a "growling" sound after the headlight assembly went down.
Thanx to members on the forum that recommended that I change the nylon gears with the aluminum ones.
Anyways - new problem. Now the headlights will come on, but the headlights don't flip up.... Any ideas??
Thanx in advance
Check fuse #6 in the footwell. If you didn't disconnect the battery as you were working it may have blown. That would stop the lights popping up
Lights don't pop up at all with the key off (turn the lights on...you can see them on, but they don't pop up).
With the car running, sometimes one light will pop up (not always the same one), once in a while both will work, but 99% of the time none of the lights pop up.
I would check your headlight switch. Try wiggling it. Sometimes they go.
Also, I believe there is a relay that controls the rising of the lights. I don't remember where it is located. Check the passenger and engine fuse blocks. It may be marked. If you find it try swapping it for another of the same time.
Did you connect the headlight that you repaired correctly, both electrically and mechanically? Is the linkage of the one you fixed in the same location as the other one?
Yes, the headlights were reconnected correctly. When the gears were first replaced, everything worked as it should (by the way, it even sounded quieter when the lights were raising/lowering). When the car was started at night or in the garage, the lights would automatically pop up. It's just after a couple of weeks that this problem has started to occur.
I'll check the relay next.
I am having the same problem as well. I do notice with mine that if i manually turn the headlight motor just one click, then go back in the car and try to turn on the lights that it will work. However this is only a temporary fix, the motor gets locked at the bottom after a few hours.
Relay 44 in the passenger footwell fuse box is for "Automatic Lamp Control Headlamps" what ever that is. I would double check that you connected tightly any electrical connectors that you disconnected during the gear replacement process.
Does your car have the twilight centennal feature? If yes, turn it off and try the lights.
Yes, the car has the twilight feature. It seems that it is "standard" for Canadian corvettes - I cannot turn that option off......
The relay seems fine. Then I tried "loosening" the manual headlight adjusters and it worked ! TWICE..... now back to the same problem again. ARGHHH !!!
(Almost makes me want to go to the C6....JUST so I don't have this problem anymore.........)
Before you go springing for big $$$$ for replacement motors do a search on headlights won't come up or head lights won't pop up. There is a lot of reading and suggestions. One that might be worth pursueing is the headlight control module going bad. Another has to do with the metal replacement gear sets causing the motor to over torque on the down cycle causing them to stick down. ( makes some sense since you manually strted them up and they worked for one cycle.) There are suggestions on how to check for both problems and others as well. Several had exact descriptions of your problem. just my 2cents.
Thanx! I'll look into that...especially the motor over torque.......
