A freind has just had his 03 Z06 dynoed and has the following mods,
The cars a 2003 Z06 with dynatec powermaxx system (long tube headers, cross pipe, and high flow cats) wide carbon air bridge with smoothie coupling and vortex cold air intake, and a tune.
He got 375rwhp and 413tq. I think these figures are pretty good considering no head or cam work. As I usually hang in the C3 section, just thought I would post to get opinions.
Any one have a bone stock 03 dyno sheet to compare?
As we all like dyno sheets,
Reason: added dyno sheet.
I have almost exactly same mods but LG pro headers. Made 380/370. His torque number is higher than normally seen on here. Any guesses why? I would sure be pleased if I had 413 number.
So if the Torque figure is too high, does that mean the BHP numbers would be off as well?
Would it be the fault of the dyno and or operator?
What would cause this problem, any ideas?
Thanks for the input so far.
OR
Is it possible some other mods have been made to the car that he hasnt mentioned or is unaware of that would give torque figures like that? I thought HP and TQ were directly related???
Reason: after thought
Vortex cai and / or a good single intake cai, Honker, Calloway, Cyclone, produces very good tq numbers. non turbulant High Air velocity moving into the tb and heads produces more tq. double airtake systems can produce turbuant air moving into the tb. More volume, but not as high velocity.
but I also agree those tq numbers are high, should be closer to 380-385 rwtq
So, at 4731rpm, the engine is calculated as producing 369 BHP which is correct looking at the graph.
A dyno measures torque and then converts it to BHP. If the BHP figures are correct, surely, therefore, the TQ numbers must also be correct or am I missing something?
