I have the oil pressure sending unit problem. I've read the DIY proceedure. Being that I'm a shadetree style mechanic, I'm a little intimidated by the intake manifold movement. I've heard that there is a proceedure where a hole is drilled through a cowl above the sensor. Are there any pics of that proccedure? Has anybody done this? Thoughts or tips are greatly appreciated.
Do the intake-it's not a big deal. There is a post on the hole drilling, used the advanced search to find it. If you have a torque wrench and the fuel line seperation tool, do the right thing and pull the intake and do a relocation kit to move it to a more accessable place. You'll be a wiser DYI'er when your done and know how/where to replace the knock sensors when they go.
pulling the intake manifold is really simple, took me less than 10mins. plumbed some new lines and re-routed my OP and now if it goes out all i have to do is pull my frc and bam there she is. Worth the time to do it right and not hack at your lady. -=]
Fuel line separation tool? Can I rent one? Expensive to purchase. How about the manifold gaskets? They are made of rubber arent they? Can I reuse them or go with a new set.
Nope, you can get them any were and there not expensive.. I usually pull the Fuel pump fuse and run the car until it dies then the lines are depressurized.
Well I just read all 29 pages of the DIY pages. Seeing that the failure rate is pretty high and I'm probably going to have the replace the gizmo more than once, I'm gonna go with the hole in the cowling route. I think I'll order one from Chevy and take advantage of the 1 year warranty. If its really bad I'll go with he relocation kit. I want to say thanks to all for your inputs. Thanks again from a new-be!
Bet you regret it this way. 29 PAGES, what are you reading? 2-3 pages should cover the whole thing.
What are you going to do when you have to replace your HVAC vacuum line, drill a hole in the firewall?
Seriously, go with removing the intake. You really don't need to REMOVE it, just unbolt it so that you can slide it forward. You will be able to move it forward enough to get to the OP unit.
I wanted to get a good feel for what others were doing and what I think I'm capable of doing.
It's actually MORE work to cut the hole, plus you have a hole you have to patch to keep water out of the back of the engine. Many people have a hard time getting the wipers off and the plastic under them can crack especially if the car sits out alot and the plastic has gotten brittle.
i paid to have mine done...it was 125 for the install and two weeks later the sensor went bad again...the ASE mechanic did it again and its been a little over a year and not one problem.
Did you read the post last week where the guy cut the hole in the cowl (and also cut some wires in the process but didn't know it) and had all kinds of problems. I still don't know if his car is fixed yet.
I'm another one that believes that if you have to do it. Do it the right way, pull the intake. I have nothing against a shortcut if it works, but not at the expense of chopping up the car and causing possibly even more damage.
