Lowering help needed.
Old Aug 23, 2009 | 07:57 PM
IRON MAIDEN's Avatar
IRON MAIDEN
Default Lowering help needed.
I tried to search the forum with no luck. I have a 97' couple with 17/18 wagon wheels. I plan on getting wheels soon but for right now I want to lower both the front and rear. Is there a thread that tells how it is done with pics? I've found threads that talk a little about being able to get 1-1.5" front and rear by just adjustments. Can someone steer me in the right direction.
Old Aug 23, 2009 | 08:02 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Try this link.
Bill K
http://www.frankhunt.com/FRANK/hobbi...5_Lowering.htm
Old Aug 23, 2009 | 08:11 PM
IRON MAIDEN
That's what I was looking for. Thanks
Old Aug 24, 2009 | 12:01 AM
Indy's Avatar
Indy
I like wagon wheels on a lowered Vette
Old Aug 24, 2009 | 01:49 AM
IRON MAIDEN
That comment and your avatar sure worked well together.
Old Aug 24, 2009 | 02:04 AM
The NNIAL8R's Avatar
The NNIAL8R
St. Jude Donor '11,'13
"I voluntarily took 60 days off from OT"
Be certain to DOUCHE the lowering bolts with WD40 or something similar...especially the front...It's kind of tricky getting to the threads below the leaf spring...use a can with a nozzle for best results...Also, I found it necessary to use a 10mm wobble socket to get on the front lowering bolts without having to pull the shocks....Turn the front bolts COUNTERCLOCKWISE all the way out until they bottom out...You'll still have plenty of tire clearance...
The rears are another story...Leave about 3/8 of an inch threads exposed above the nut...Lower the car and test drive it to allow the suspension to "settle"..You may want/need to lower it some more or raise it to match the front...
OP, if you run into a snag you can call me at 719-269-7998
Old Aug 24, 2009 | 10:50 AM
IRON MAIDEN
Thanks. I plan on tackling this next weekend. I need to go buy a new floor jack first.
Old Aug 24, 2009 | 11:51 AM
hotwheels57's Avatar
hotwheels57
In C5 Tech, use search or search this forum (in the red banner), use keywords "lowering a c5".
You'll find hundreds (thousands?) of past threads with images, caveats, pros/cons, debates and helpful hints.
Since you car is a '97, you'll most likely experience the same issues that most do with this modification. Don't stop at just one past thread, read them all. Read about them before you experience them so you're prepared with tools, lubricants and patience...
To Lowering help needed.
