Dried tree sap? Really?
Old Aug 24, 2009 | 06:10 PM
deimis's Avatar
deimis
Default Dried tree sap? Really?
So forum, I park on the street (no garage for my apartment) without a car cover (first mistake). I noticed that there was some clear syrupy substance on my hood from the pine trees above where I park. So as you can imagine, I wasn't in the best mood. Then as I go to clean it off, we get torrential downpours all night.
So I'm stewing away waiting to go see the damage after the rain, and lo and behold, my black car looks like someone took a bunch of white out and had a field day on my hood.
Its dry to the touch and I have to literally scrape this crap off. My question is this. Does anyone know of any cleaner/product that will aid in the removal of this mess without harming my paint? I'll post pics when I get a chance. I've been here for over a year and a half and never seen sap from this tree...what gives?
Old Aug 24, 2009 | 06:17 PM
dangerz's Avatar
dangerz
St. Jude Donor '09-'10
Claybar and rewax.
Old Aug 24, 2009 | 06:18 PM
GS Ron's Avatar
GS Ron
I have used Adam's Detail Spray with success on tree sap from pine trees.......Spray it on, let it loosen the sap, wipe it off. Works good for me...........
Old Aug 24, 2009 | 06:21 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
I would wash the car first and get off as much as you can. If there is still remaining sap - you might try some hot (not boiling!) water to dissolve it. Once it's gone, claybar will remove any residue and then you should be able to re-apply your wax or sealant.
Next - get yourself a weatherproof cover if you aren't able to garage park it.
Old Aug 24, 2009 | 08:30 PM
BUBBAS 01Z06's Avatar
BUBBAS 01Z06
Originally Posted by dangerz
Claybar and rewax.
100 %
Claybar works wonders !!!
Old Aug 24, 2009 | 10:08 PM
BanditDude's Avatar
BanditDude
WD-40 and rewax the spot.
Old Aug 24, 2009 | 10:09 PM
steve8's Avatar
steve8
I'd try a clay bar and or wd-40, but both are a definite maybe.
After that I would suggest stoners tarminator.
Old Aug 24, 2009 | 10:38 PM
flarick's Avatar
flarick
WD40, put it on and let it sit for a minute or so then start wiping it off. Depending on how much sap is on there, you will probably have to repeat this several times. Once it is off, rewax.
Old Aug 25, 2009 | 12:32 AM
my6thvette's Avatar
my6thvette
Isopropyl Alcohol
Old Aug 25, 2009 | 07:33 AM
dougbfresh's Avatar
dougbfresh
Try prepsol, works great. It a pre-paint cleaning solvent used in body shops. I always keep a gallon around works great on getting all kinds of stuff off.
Old Aug 25, 2009 | 08:14 AM
deimis's Avatar
deimis
thanks guys! time to get to work!
Old Aug 25, 2009 | 08:46 AM
NC99's Avatar
NC99
White kerosene mixed 50/50 with water. It will take off all the wax, but will safely remove the tree sap. Then wash the car with dish soap to remove all the wax from the rest of the car. Claybar and then start fresh with 3-5 coats of Zaino Z5 and then start layering with Z2.
Old Aug 25, 2009 | 09:02 AM
jrose7004's Avatar
jrose7004
Use Goof Off or WD-40 and rewax.
Old Aug 25, 2009 | 10:49 AM
But there are some other good suggestions here that are new to me.
To Dried tree sap? Really?
