ripped off?
Old Aug 27, 2009 | 05:38 PM
Warped Sol's Avatar
Warped Sol
Man, I've never experienced the column lock issue. The first thing I did upon buying my Z '03 (used) was install the CLB. $50 insurance policy that should pay off.
Old Aug 27, 2009 | 07:17 PM
dobewillie's Avatar
dobewillie
man you got screwed 50 bucks and 20 minutes to install a clb live and learn sorry
Old Aug 27, 2009 | 08:54 PM
zagger's Avatar
zagger
Can't believe this subject still comes up. There is so much written on column lock and how it works, when it fails and most important how to fix it permanently. Yet there are still people that will argue about the GM fix. Best one is when someone writes they never had a problem, guess what the ads are stacked against you. As the car gets older the risk goes up and it will happen sooner or later. Instead of ranting about it, read up on the subject then install CLB. It's that simple, $50 later and it's solved forever. And all of you that stated they can hear buzzing when inserting key into ignition you are in risk of getting stranded. If you chose to ignore good advice many of members made then you deserve to be taken to the cleaner by the dealer. CLB works and all the guys who spent time and wrote posts with pictures did not do it because they have vested interest in the product. I understand the OP got tricked by towing to a stealer and at that point they had him but for the rest of you still on the road get it dealt with before you find yourself in same position, GM fix has proven to be unreliable so don't think you will not have a problem because it was done.
Old Aug 27, 2009 | 09:05 PM
SCM_Crash's Avatar
SCM_Crash
I CAN believe it keeps coming up. Lets face it, we're all VERY angry at GM for ignoring this problem on a $50,000 car. I still don't understand why there's no class action law suit.
Old Aug 27, 2009 | 10:29 PM
joshtownsend's Avatar
joshtownsend
Originally Posted by dougbfresh
WHY do people keep fighting GM on this-it's worth $50 no to have to talk to anyone there.
Could not have said it better myself
Old Aug 28, 2009 | 01:09 AM
SCM_Crash's Avatar
SCM_Crash
On an auto car that's not such a big deal. $50 and you're set. But with manuals, the CLB leaves the car without one of it's theft deterrent systems. Now it'd be even easier to steal my car. I think that's unacceptable really. I installed the CLB because I'm forced to. But the cost of a fix being $50 isn't the real cost. We're paying $50 for a band-aid or work-around. Not the fix.
GM says it'd be too expensive to fix. I'd like to know what their fix is.
Old Aug 28, 2009 | 01:44 AM
Virtual Geezer's Avatar
Virtual Geezer
Originally Posted by 1998whitecoupe-a4
Also the dealer was kind enough to add the fuel cut off and set it to 2 mph. I used a HP Tuner Suite to change that to 250 mph.
Funniest thing I've read all day!
Old Aug 28, 2009 | 02:31 AM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
I did the same thing on mine using EFI Live. Best thing that can be done in my opinion.
Old Aug 28, 2009 | 02:35 AM
DeeGee's Avatar
DeeGee
Originally Posted by deimis
Its frustrating to see these threads where people chance it. How many times do we read about the GM fix NOT working??? I've lost count. Buy the CLB already, it can, and most likely, WILL happen to you given a long enough time horizon.
So true
Old Aug 28, 2009 | 12:11 PM
Vega$Vette's Avatar
Vega$Vette
Do you really think locking the steering is going to stop anybody from stealing your car if the really want it?
Old Aug 28, 2009 | 03:59 PM
SCM_Crash's Avatar
SCM_Crash
No. Someone stole my 2002 WS.6 Trans Am. Which had a column lock.
But it still bothers me.
Old Aug 28, 2009 | 07:36 PM
David426's Avatar
David426
I think thieves already anticipate having to break the steering column lock before stealing a car... Its just one less thing to tear up when you have the CLB done.... Then again a thief does not know if you have a CLB and would probably bust up the steering column anyway
Old Nov 18, 2009 | 07:16 PM
  #33
cepter's Avatar
cepter
Default Hp tuners / efi live 2mph fuel shut off clb
I live in Rhode Island.. Does anyone know where I could go to have the fuel shut off increased so it doesnt shut off at 2mph.. or would someone with tuning software consider renting it to me to fix my problem ?
thanks
AndrewMonda@gmail.com
Old Nov 18, 2009 | 08:11 PM
  #34
Dale M's Avatar
Dale M
Default How do ya know
Hi. I bought a used 01 Z06. never had the lock problem(Yet)
Is there a way to tell if your car already has the Mod to fix the problem? would hate to be 100 miles from anywhere and have this happen..
Dale M
Old Nov 18, 2009 | 09:56 PM
  #35
HawnHog's Avatar
HawnHog
I’m a bit confused, if the dealer had done the “fix” a plate should have been installed to prevent the lock pin to engage, hence preventing the steering wheel to lock.
Easy way to check that is to see if you can move the steering wheel with the keys out of the ignition.
I too had the dealer do the “recall” on my 98 A-4, they indeed put a plate on so the lock pin would not engage and put the “K” harness on.
Had all that done AND installed the CLB as well as having the tuner "fix" the fuel cut-off as well. No more problems.
Old Nov 19, 2009 | 02:03 AM
  #36
GHL4505's Avatar
GHL4505
While we are on the subject of the CLB . . . I'd like to ask a question. I have a 98 A4 coupe. Have gone through most of the corvette problems that GM ignores, like the gas gauge problem, leaking battery, rocking seats, pulsating brake, chirpng belt, etc. The steering wheel lock up is just another thing waiting to happen. I have never had the steering wheel lock up problem. But, the dealer did the recall fix when it was in the shop for another problem. My question is . . . does the dealer fix need to reversed before installing the CLB or can you just add the CLB as is? Seems like I read somewhere that the dealer fix should be removed before installing the CLB.
Old Nov 19, 2009 | 08:45 AM
  #37
Daddyrama31's Avatar
Daddyrama31
AMENGet the CLB. If you don't, chances are it will happen again!
Originally Posted by pewter99
nope many have paid after the GM fix.
The CLB is the only way
Old Nov 19, 2009 | 01:19 PM
  #38
hatewhatownsyou's Avatar
hatewhatownsyou
where do you guys buy the CLB?
