You are going to have to know the resistance of the original key - otherwise the car will not start even if you get the broken key out of the ignition. If you can get the resistance number - then a locksmith should have a key blank - or a Chevy dealer. You also might try Gene at gmpartshouse.com.
You do need to know the resistance of the key. You might be able to take what you have to a Chevy dealer and ask for the key number. ?They list them from 1 to 15, then get the blank from a vendor here. I got mine from Eckler's. They were the less expensive. By less expensive...they were $15.00 and others were $30.00. Get the resistance/number.
The BCM measures the resistance value of the resistance of the pellet and allows the fuel system to operate. If it is within +/-10% the car will start.
To check your key value:
Set your digital volt meter to “ohms mode” and measure the value across the pellet.
