I just put 315/30/18's in the rear and coupled with the 275/40/17 up front, it looks rediculous... What tires should I get for the front to even out the sidewall appearance with the rear? This is for the stock 17" & 18" set up.
The 30 series tire has a very low sidewall - going to be hard to get a front tire that would match up well - remember you have to keep around a 1" stagger from front to back to keep the ABS/Traction Control system working right.
did you get the 315/30/18 R-S2 hankooks by chance from the tire rack that were on sale? if so the 265/35/18 is almost a 1/2" shorter so 1/4" shorter side wall.
Yes I did. I don't wan to buy new wheels. I am thinking of just getting 245/40/17's.
