[Z06] paint flaking
Old Feb 19, 2002 | 01:26 AM
TX405Z06's Avatar
TX405Z06
Default paint flaking
I noticed that the paint is chipped of and is starting to flake on the pass. wheel well. Its behind the tire where all the spray hits it from the tire.
Any thoughts on this?
I'll probably take it to the dealership its only 6 months old with 7000 miles
Old Feb 19, 2002 | 04:31 AM
NastyC5's Avatar
NastyC5
Default Re: paint flaking (TX405Z06)
Mine had the same problem in the same area :mad The dealer would not fix it under warrenty :mad I had to pay to have it fixed when I had my flames done :cuss
I hope you have better luck.
Old Feb 19, 2002 | 07:24 AM
hcvone's Avatar
hcvone
Default Re: paint flaking (NastyC5)
Corvette has the softest paint we have ever tested, I see this problem on many Vette. :(
Old Feb 19, 2002 | 01:05 PM
TX405Z06's Avatar
TX405Z06
Default Re: paint flaking (hcvone)
My Z71 has a adhesive clear film that is attached to the same area I assume its because the factory knows a 4x4 will be slinging up stuff. If someone develops this it was my idea. All $$$$ tips will be accepted
To paint flaking
