I have 93 k miles on my 01. So far this is what I have replaced
tie rod and toe rod ends.
all sway bar links
brake rotors and pads
oil pressure sending unit
belt tensioners and idler pulleys
HVAC control , bad display
dash light dimmer rheostat
bottom driver seat cushion ( just worn out at 90k miles.
And that and regular tires, belts and tune up parts and fluid changes is it. A solid reliable daily driver.
