Headlamp Motor
Old Aug 31, 2009 | 11:00 PM
mazevedo's Avatar
mazevedo
Navigator
Default Headlamp Motor
I have an 02 vert and one of the headlamp motors continues to spin after the headlamp door has closed. It opens fine, only when closing does it make a loud grinding noise for about 5-7 seconds.
Has anyone had a similiar issue? Do I need to replace the motor or is there a gear or something I can replace?
Thanks-
Old Aug 31, 2009 | 11:22 PM
TEXHAWK0's Avatar
TEXHAWK0
You probably need to replace the nylon gear. There is a supplier that makes a brass gear kit. I will return if I find a link...
Look on the Electrical tab.
http://www.rodneydickman.com/retail_new.html
Old Sep 1, 2009 | 01:40 AM
DeeGee's Avatar
DeeGee
Classic symptoms
The easy option but $$$ option is to replace the headlight motor thats making the noise but of course you end up with a new nylon gear in there which may fail again.
By far the best is to go with rodney dickmans kit which texhawko pointed you at. Its fiddly but you end up with a much better solution.
Take a look at Leaftye's sticky at the top. Run down to headlamp motors and you'll find some info and pictures.
Old Sep 1, 2009 | 02:30 AM
D C's Avatar
D C
USMC (retired)
Originally Posted by DeeGee
Classic symptoms
Best bet and worth the change.
Old Sep 1, 2009 | 09:53 AM
02MillenniumVette's Avatar
02MillenniumVette
Old Sep 1, 2009 | 07:09 PM
mazevedo's Avatar
mazevedo
Navigator
Thanks to all for the reply, I have just ordered the brass gear kit...
To Headlamp Motor
