A few questions about wheels...
Old Sep 3, 2009 | 05:07 PM
CorvetteAddict's Avatar
CorvetteAddict
Default A few questions about wheels...
I feel really, really embarrassed to have to ask this, but do the wheel caps on my '99 coupe (factory wagons) simply pop right off? They seem a little too deep in the wheel to get a good angle with a screwdriver, plus I don't want to scratch the wheel.
Also, having bought the car used the wheel lock key is missing and I cannot locate the special card that accompanies it. After searching here, I read a post that someone was able to send their VIN to a company which was able to sell new wheel lock keys. Anyone know what company can do this?
I know these are really novice questions, thanks for bearing with me.
Save the wave!
Old Sep 3, 2009 | 05:16 PM
renegad44's Avatar
renegad44
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
Never paid much attention to the wagon wheels, but you should be able to take the wheel off without popping out the center cap, maybe? I usually removed my wheel first, than popped them out. As for the lock, did you look in the rear compartment, under the left rear storage bin? There's an indentation where the locking key should be stored.
Old Sep 3, 2009 | 05:22 PM
NorCalVette Kid's Avatar
NorCalVette Kid
St. Jude Donor '09
Pop them out from the inside of the wheel.
Old Sep 3, 2009 | 05:46 PM
CorvetteAddict
Remove the wheel first? on the wagons the center cap covers the nuts as well. They're the factory chrome wagons if that makes a difference. Just went out to the garage, no way I can push them from behind inside the wheel. Come to think of it, I might be able to get some string or wire behind the part of the cap that covers the socket and pull, unless anyone knows a better way?
And yes, I found the indentation in the back, checked all of the rear storage areas, and peeked under some of the lose carpeting just to be thorough. No lock key =/. Anyone know a way to order a new one using the VIN?
Thanks for all the responses!
Old Sep 3, 2009 | 06:44 PM
NorCalVette Kid
St. Jude Donor '09
You're right the center cap do cover the lug nuts! Looks like there's slots to pry open the center?
Old Sep 3, 2009 | 06:49 PM
renegad44's Avatar
renegad44
That's what I thought also, like I told the OP, I usually take my wheel off first, but they were "thinspokes," and the ones I have on now, than pop them from the rear after wheel is off. I'm not sure, but you "can't" take the wagon wheel off without removing the center cap?
Never mind, I see what you just posted, yep, the center cap covers the lugs.
If you have wagon wheels, you may have OEM locks, don't dealerships have a "universal key" to use? Check with your Chevy dealership(?)
Old Sep 3, 2009 | 07:13 PM
steveovette's Avatar
steveovette
Yes just pry the center caps off with a flat blade screwdriver covered with a rag. The locks can be removed with a universal set that your local GM dealer will have. In my service dept. thats all we use as the customers never remember where their key is. This will only work if you have the factory lock nuts. If not just hammer an old smaller socket on the nut and wrench them off.
Old Sep 3, 2009 | 11:52 PM
They do come off with a small flat blade screwdriver.
Old Sep 4, 2009 | 12:10 AM
jrose7004's Avatar
jrose7004
I've never had wagon wheels.
Old Sep 4, 2009 | 07:42 PM
CorvetteAddict
Thanks for the pic! I guess the previous owner must have put on a black/grey checkered cover in the center of the wheelcap, I never noticed the little tabs under there.
Universal key at the dealership? sounds great. I've been meaning to get these wheels off and bleed my brakes all summer.
Thanks again for all the help
Old Sep 4, 2009 | 08:49 PM
JanMan99's Avatar
JanMan99
Stevovette has the right idea.....at this time I have factory wagon wheels & a flat blade screwdriver covered with a shop rag will pop them loose for removal. Get one area loose & then work around & they will come off. LOL
Old Sep 5, 2009 | 08:20 AM
10U 99's Avatar
10U 99
St. Jude Donor '08-'09
there is a dark colored ring that attaches to the cap. tabs on the ring fit into the slots to secure the ring.
this is the caps I had on my wagons way back when.....
a set of these come in handy removing trim pieces without damage
Old Sep 7, 2009 | 03:23 AM
CorvetteAddict
Hmm, those do look handy. What are they and where are they sold?
To A few questions about wheels...
