dont really care bout racing i just found a local differential out of a auto vette, and wanna get my car up and running instead of just letting it sit ....
It will not be as quick acceleration-wise. You will not be pleased. But, if you're bent on doing it, make sure you pull the A4 adapter plate off the front before installing it.
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Seeing you have a 6 speed with 3.42 gears and you want to install a diff out of an automatic you will be sorry, Not only will you lose top speed, You will lose your acceleration, 2.73 gears are to high for a 6 speed trans, I know you can find a good used diff if you look with the correct gears of 3.42, No way I would install 2.73 gears in a car with a 6 speed.
Keep in mind you will also have to have the computer re tunned for the different gears.
Let the car sit till you find the correct one.
Bill K
You don't have to do anything to retune for gears with a manual tranny only and automatic and that is to correct the shift points.
You'll have a higher top-end but much slower acceleration.
Bill K
Seeing you have a 6 speed with 3.42 gears and you want to install a diff out of an automatic you will be sorry, Not only will you lose top speed, You will lose your acceleration, 2.73 gears are to high for a 6 speed trans, I know you can find a good used diff if you look with the correct gears of 3.42, No way I would install 2.73 gears in a car with a 6 speed. Keep in mind you will also have to have the computer re tunned for the different gears.
Bill K
You do NOT have to do any programming with a 6 speed. Only on A4s to change the shift points.
I would not put 2.73s or 3.15s in a 6 speed.
OP
When you say it's "going out" what exactly do you mean?
Sorry to hear of your misfortune with your diff...
If you are going to replace it, you may as well get 3.90 or 4.10 ratio. Depending on where you are located, there are several good shops around the country that can do a good job, or order one from DTE.
It will really wake up you car. I love the 4.10s in my car.
