[Z06] im confused
Old Sep 8, 2009 | 10:52 AM
Evil03's Avatar
Evil03
Default im confused
Ok I'm lost ,I've found more than one article stating that the 03 zo6 actually puts 425 to the crank even though it stats 405 has anyone else seen this even on a gm forum it was posted
Old Sep 8, 2009 | 11:15 AM
03 Z-oh-6's Avatar
03 Z-oh-6
Let say a bone stock 03 z06 dyno's 360rwhp which is very well possible. If you take 360 divided by .85(drive train loss) you'll get 423. It's safe to say the LS6 might be a tad underrated, but to put an exact number on it is pretty tough.
Old Sep 8, 2009 | 11:37 AM
Stevo92z28's Avatar
Stevo92z28
They are probably closer to 425 then 405 crank hp i think. Probably in the 415 range.
Old Sep 8, 2009 | 01:16 PM
zeevette's Avatar
zeevette
Whatever the number is, it's not enough.
Old Sep 8, 2009 | 01:56 PM
JuicedH22's Avatar
JuicedH22
There is usually always some conservatism added to the factory numbers. This is sometimes done to avoid scrutiny if it doesnt make those numbers (think of when the rx-8 came out, and they then had to come back later and say they were wrong about the power, and downgrade it) as well as emissions/ gov't regulations, etc...
Furthermore trying to back calculate an estimated drivetrain loss is often silly, and unless substantiated, is worthless.
But most of all, it doesnt matter. The power to the wheels is all that really matters, not what the crank sees. So if you want to know how much power you have, strap it to a dyno and talk about your Wheel hp.
Old Sep 8, 2009 | 03:11 PM
TK6's Avatar
TK6
I believe the horsepower ratings these days are with all the accessories attached. (Alternator, etc.) So if you were to run a stock LS6 (405 hp) on an engine dyno sans accessories, it seems likely it would put out about 425.
Old Sep 8, 2009 | 03:26 PM
AU N EGL's Avatar
AU N EGL
Why should you care?
You want us to take 20 hp AWAY??
Old Sep 8, 2009 | 04:03 PM
Bad95killer's Avatar
Bad95killer
mine '04 BONE STOCK - 365rwhp = 429.4HP
Old Sep 8, 2009 | 06:58 PM
JuicedH22's Avatar
JuicedH22
based off some random "guess" at drivetrain loss? Some random guess that someone said in a thread somewhere, and it spread around so people just use it, not knowing if it is factual or not?
Only kids and salesmen talk about crank hp, people who drive, or make power, talk about wheel hp, or timeslips
Old Sep 8, 2009 | 11:23 PM
Millenium Z06's Avatar
Millenium Z06
Moderator
While I agree with your opinion and comments, it's widely known and accepted that an manual trans car will loose 12-15% thru the drive line and an auto will loose 15-20%. A good percentage of the loss is with the hypoid type rear gears.
Old Sep 9, 2009 | 01:17 PM
JuicedH22's Avatar
JuicedH22
I agree. My problem with it, is that I have seen no actual substantation, such as running on an engine dyno, then on a chassis dyno and calculating the difference.
I am a firm believer in not just believing what I read on the internet, especially just a public forum. For example, if you read on this forum, a lot of people will try to tell you the 01 zo6 wheels were the lightest Or that they are made out of magnesium Or in another thread I replied to this week, that an A/F ratio of 12.6 on an n/a car is lean
Old Sep 9, 2009 | 03:08 PM
2K3Z06's Avatar
2K3Z06
From: KADS- If it has wings or an engine, I can break it. Dallas TX
The power should be as rated. These tests are now conducted per SAE standards. Because some used to take off belts and other such crap. All manufactuers use the same standards.
Old Sep 9, 2009 | 03:31 PM
meadowz06's Avatar
meadowz06
St. Jude Donor '09 and '13
Power loss percentage is around 10-12%. 15% is pushing it a bit.
To im confused
