HELP-AC button blinks-system won't turn on
Old Sep 13, 2009 | 11:24 PM
mmrm0602's Avatar
mmrm0602
1st Gear
Default HELP-AC button blinks-system won't turn on
When I try to turn my AC on, the button just blinks and the AC system doesn't come on. Does anyone know what's happened and what I can do to fix it. THANKS !
Old Sep 14, 2009 | 01:33 AM
DeeGee's Avatar
DeeGee
You dont say in your profile where you live but my guess is somewhere colder.
Below 35 degrees the AC will not switch on. The light blinks to let you know that the system is inhibited.
A/C (Air Conditioning): This button turns
the air conditioning compressor off or on under most
conditions. The light on the A/C button will come on
when the compressor is operating in either the automatic
or manual mode. The air conditioning does not operate
at temperatures below approximately 35F to 40F
(2C to 4C). The light on the A/C button will flash if
pressed when air conditioning is not available. The air
conditioning cools and dehumidifies the air coming into
the vehicle. The air conditioning cannot be turned off in
defrost and defog, as it helps to remove moisture from
the vehicle. It also helps to keep the windows clear.
If the system is operating in the AUTO mode, turning
the air conditioning off will delete AUTO from the
digital display and show current mode and fan settings.
The AUTO button must be pressed to return to the
automatic mode operation.
The air conditioning may be forced off at high engine
speeds or high engine oil or coolant temperatures.
(Outside Air): Press this button to provide outside
air. The light on this air intake button will come on to
show when it is operating. When in the AUTO mode,
the system automatically selects outside air instead of
recirculate, as required, to control the temperature in the
vehicle. By pressing outside air, the system will lock
into the outside air mode. Any adjustment to the air
intake must then be made manually. Outside air should
be used when trying to defrost or defog windows to help
reduce moisture inside of the vehicle.
Old Sep 14, 2009 | 08:45 AM
electric_yogurt's Avatar
electric_yogurt
It depends on the combination of outside temp, inside temp selected and direction of airflow / airflow outlet (ie windshield or floor say) selected. I don't understand how it decides, I just change the airflow selection until it comes on.
To HELP-AC button blinks-system won't turn on
