It's been done before. I used to work at a Corvette only dealership (that does retail repair work).
Some guy failed at installing an aftermarket exhaust and brought it in to the shop. He had unbolted the flange and cut the over-axle pipe with a saw to get the oem parts off. Then he didn't know that automatics need to have the rear subframe unbolted and lowered an inch to help with instal clearance.
Nothing was hurt except his ego.
Good to know, many thanks, I'll just make sure I get to drive with the exhaust off, not my wife....
You'll be good it won't hurt anything. Just be prepared to get a lot of looks. I drove my camaro open headers for like an hour and half on the highway to an exhaust shop. Wow was it noisy but my baby ears can take it.
... Would it be to drive my car a few miles without any cat back or turn downs??
I am having the exhaust modded and need to have it removed and replaced at a later time.
I'm all ears guys, let me know
-Ed
I used and old set of header bkock off plates, cut the ccenters out with a torch, took a big wad of steel wool and stuffed it into the header collector and put a wire screen between the collector and block off plate, Still sounded like NASCAR, but didn't draw any of the law.
