is it work to use the stock ls7 brake pads and disk for c5 zo6?? did any one try it??
I am in middle east and the shipping cost would be very expinseve to order an after market brake system due to the high weight of brake disk
C6Z (LS7) brakes can be used on the C5Z. It's a dirrect swap (I think). Need the lines, calipers, rotors(brake disk) and pads. Requires 18" or larger wheel to fit C6Z larger diameter rotors.
Brake Pads ? No not a direct swap
Different size
C6Z brakes can be put on the C5 but also need different wheels 18" min wider offset to fit over the C6Z calipers
