c5 corvette space saver spare
Old Sep 22, 2009 | 02:02 PM
ricksterc5's Avatar
ricksterc5
Cruising
Default c5 corvette space saver spare
i would like a spare along with my run flats , i saw the thread about the gto wheel and tire.. however i was wondering will a c4 space saver tire fit on the front of a c5 corvette and the rear...also if a rear blows out then would the front wheel and tire on a c5 fit the rear then put the space saver tire on the front ???any input would be appreciated...
Old Sep 22, 2009 | 02:58 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
You want a space saver spare ALONG with runflats? That's kinda like wearing suspenders and a belt? You do realize that the spare was nixed in favor of the run flats to save space and weight. Also, with a spare, you'll need a jack and a lug wrench.
Personally - if you have runflats, a spare is unnecessarily redundant.
Brought to you by the U.S. Office of Redundancy Department
Old Sep 22, 2009 | 03:13 PM
AU N EGL's Avatar
AU N EGL
DOnt need it.
if the run flat goes flat, not likely, you can drive upto 100 miles at 50 mph.
or just use your cell phone and AAA and request a flat bed
Old Sep 22, 2009 | 03:43 PM
jbondfl's Avatar
jbondfl
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
First, runflats don't go flat
and even if they did, the compact spare you are freferring to has the same speed/mileage limitations that your runflat does so you gain nothing.
Old Sep 22, 2009 | 07:09 PM
2KFRC5's Avatar
2KFRC5
What happens to a run-flat if you run over something that shreds the tire, or a catastrophic failure that shreds the tire? Can you still drive on it at the 50mph/50mile claim?
Old Sep 22, 2009 | 07:40 PM
ricksterc5's Avatar
ricksterc5
Cruising
Default shredded tire, run flat
as i understand it...you can still drive on the run flat..
Old Sep 22, 2009 | 07:41 PM
ricksterc5's Avatar
ricksterc5
Cruising
also i was told that the sidewalls of the runflats act like 2 washers and you are driving on those..
To c5 corvette space saver spare
