[Z06] Vararam ???
Old Sep 23, 2009 | 10:46 AM
ZEE-OH-6's Avatar
ZEE-OH-6
Default Vararam ???
I have a stock 2004 ZO6 with a Vortech air intake. If you have installed a Vararam intake was it worth it over other intakes - could you feel the power gain ( i.e., 40 hp as claimed by the manufacturer ). Also, since the Vararam occupies the front air intake ports does this lack of cool air to the engine compartment cause the Vette to run hotter ?
Thinking about buying one if it is really worth it ?
Old Sep 23, 2009 | 11:05 AM
cw1970's Avatar
cw1970
I have installed the Vararam on my '03 Z06. I can't say on how it compares to other intakes because it's the only one that I have experience with on the corvette. As for as feeling the 40 hp, I can't honestly say that I felt 40 hp, but I definitely feel it pull harder above 4,000 rpms. The faster you go, the more air is rammed into the intake from the outside. Also on a plus side, with the Vararam you are drawing cooler air into the intake vice the hot air from the engine compartment from open element air filters.
Also it does not effect the engine temps of the corvette because our cars were designed to be bottom feeders. Meaning drawing air from underneath the car.
Old Sep 23, 2009 | 11:22 AM
ZEE-OH-6's Avatar
ZEE-OH-6
Thank you cw1970 ! I understand the bottom feeder feature but I thought on the ZO6 they had the fog lights removed and cooling screens added to further cool the LS6 ?
Was the Vararam difficult to install ?
Old Sep 23, 2009 | 11:27 AM
cw1970's Avatar
cw1970
If that's the case, then my car runs the same temps both in coolant and oil temp before and after the install.
It took me about 6 hours to install because 1. I was a newbie (this is my first corvette).
2. the included directions weren't all that great, I had to download additional info from the internet. and 3. I don't had to run back and forth to the parts store for tools. My tool collection was lacking.
I see that you're local to me. If you need a hand installing or want to check out the set up on my car, just let me know.
Old Sep 23, 2009 | 11:39 AM
Bad95killer's Avatar
Bad95killer
yup agree i installed mine in 3-4 hours and feeling with the difference above the 4,000RPM and worth it.
Peace
ZEE-OH-6's Avatar
ZEE-OH-6
How difficult is it to change / clean the filter ?
Do you pick up a lot of debris that's forced into the Vararam?
Old Sep 23, 2009 | 11:44 AM
ZEE-OH-6's Avatar
ZEE-OH-6
Awesome Photos - did the hood have to come off ?
Old Sep 23, 2009 | 11:45 AM
Bad95killer
nope but i loved to do it with HOOD off better and faster
Old Sep 23, 2009 | 11:48 AM
cw1970's Avatar
cw1970
To change and clean the filter is not difficult. It's just a tight fit. I still have the stock duct behind the Vararam. I just cleaned mine last week for the first time in about 10 months that I have had it installed. There was some dirt, but nothing more than usual. Some guys clean it after every other oil change. Oh btw, my car was a weekend driver up until 2 months ago. Now i sort of daily drive it and it's not that difficult to mantain. They do have a cleaning kit for the Green airfilters.
Old Sep 23, 2009 | 11:49 AM
cw1970's Avatar
cw1970
BTW Bad95killer, that's a badass car bro!!
Old Sep 23, 2009 | 11:51 AM
ZEE-OH-6's Avatar
ZEE-OH-6
Thanks GUYS, U ROCK !
Here's a real dumb question - is it California Smog Legal ?
DUHHHHHHHHHH
Old Sep 23, 2009 | 11:52 AM
dbaker's Avatar
dbaker
Installed mine about 2 years ago.I had a pal help,took about 3 hrs.Added the Power Duct last spring.
Worth the money & effort.I clean my filter every OCI( 3-4k).Takes about 10 min to clean.
\db2
Carolina
Old Sep 23, 2009 | 11:54 AM
Bad95killer
thanx buddy
Old Sep 23, 2009 | 12:25 PM
cw1970's Avatar
cw1970
DUHHHHHHHHHH
It does not have a carb#. So technically it's not.
Old Sep 23, 2009 | 01:20 PM
ZEE-OH-6's Avatar
ZEE-OH-6
So I might have to remove it if the Smog ***** see it ?
Old Sep 23, 2009 | 10:50 PM
PRE-Z06's Avatar
PRE-Z06
It netted a .1 and 2mph in the 1/4 over the blackwing I had on previously, so the ram air effect works. I run the same 178* while cruising as before also. I recommend installing the z06 screens in the front bumper to help keep big debris out of the filter.
Old Sep 23, 2009 | 11:23 PM
ZEE-OH-6's Avatar
ZEE-OH-6
Thanks ! I have a ZO6 so the screens are in place.
To Vararam ???
Old Sep 24, 2009 | 12:22 AM
winters97gt's Avatar
winters97gt
I just installed mine today. It went in place of the stock box/zip tie mod which I have been playing with for a while, going back and forth. My trap speeds were fairly close with each in the 1/8, with my fastest pass coming with the stock air box on.
I would like to consider myself to have a good sotp meter. I pay close attention to how my car feels while accelerating. I felt absolutely nothing under 55mph, and I made a lot of WOT pulls. At the top of second gear, you will notice a little increase, and with third. My car goes in for a dyno tune next week, and I will be posting track times on it. Last week, I ran 7.82 at 90.08 with a 1900ft DA. Last year, my fastest MPH was 90.84mph at 900ft DA. Both runs were done in 100% stock trim, except this year I had drag radials.
Old Sep 24, 2009 | 12:28 AM
ZEE-OH-6's Avatar
ZEE-OH-6
So if I understand you correctly, the Vararam really is not worth the time & $$$ ?
Old Sep 24, 2009 | 12:46 AM
winters97gt
Nobody has posted that here yet
The piece itself is cheap, but the performance gain, if you search is worth it.
