What Air Intake To Install ?
Old Sep 28, 2009 | 04:07 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
I like the looks of this dual cone chrome intake system at WCC. Has anyone tried this type/results?
http://www.westcoastcorvette.com/p-2...5-logo-c5.aspx
Old Sep 28, 2009 | 04:37 PM
oh1vette's Avatar
oh1vette
Check these guys out if ya want powdercoated pipes...i've been thinking about the red, but not sure if it'll match my 01 mag red....
http://www.vetteworksintl.com/c5intakesystems.html
Old Sep 28, 2009 | 05:02 PM
MSG C5's Avatar
MSG C5
Thanks. I wish they showed pics of the powdercoated pipes...
I've seen both the chrome and the stainless up close and the chrome really pops!
Old Sep 28, 2009 | 05:37 PM
TR97C5's Avatar
TR97C5
Originally Posted by hotwheels57
But which ones produce 30-40hp that you mentioned above?
The highly touted VARARAM and HONKER produce approx. 16-18hp according to which ad or article you read.
Most performance modification horsepower improvements are achieved at rpm levels that few street cars operate at...at least for any sustained period of time. And then they require a tune to actually see full benefit. So, is it the modification or the tune that increases the performance?
Otherwise, owners do it mostly for appearance, sound, bragging rights or bench racing.
Hotwheels I am kind of on the same page here with you in your thinking. From what I have seen of the Vararam and from track results (& mph) the Vararam works because not only bring in cool pressuized air but imo it has to be leaning out the afr (which will produce more power) when reaching a high MPH, there for increasing, performance. et and mph. But like you said you going to need to be driving at high speeds to see the full performance gain. I also agree on your comments on the tune along with getting more air to the motor. Hey hotwheels take a look at my thread here I like to get you advice and thoughts on what I am thinking if what I am thinking is correct. If you want you can either reply in that thread or pm me.
http://forums.corvetteforum.com/c5-g...-ecs-tune.html
Old Sep 28, 2009 | 05:59 PM
hotwheels57's Avatar
hotwheels57
First of all, I'm not a tuner or a racer. I'm just expressing common sense and past experience of buying into advertising/manufacturers gimmick products like most enthusiasts do at some point.
Not all performance products lend themselves to improving power on cars that are primarily used for A-B transportation. Some of them can actually reduce power and reliability. If the car is tracked, that might be a different story.
From reading your other thread, it sounds like you're getting good advice from the other two members. Select a quality air intake (HONKER is certainly well thought of) and maximize it with the services of a qualified tuner.
Old Sep 28, 2009 | 06:27 PM
TR97C5's Avatar
TR97C5
Ok thanks for your input, I think I will call ECS to ask about thier tune parameters settings and run a few ideals past them using thier tune and see what they say.
Old Sep 28, 2009 | 07:30 PM
dobewillie's Avatar
dobewillie
Originally Posted by killerREDvette
vararams are nice but remember ANY resistance (any bend, corner,etc.) the shorter the better. adding 1 90 degree bend to an intake tube is like adding 3ft of strait pipe. also that there is about a 1" buffer of stagnant air that sits in front of your car at speed (why ram air hoods with intakes up on hood work.) the BIG thing to look for is any intake that is using air from outside the engine compartment, there's a usually a 30-40HP diff....check out callaway honker also.
gotta get one o these
Old Sep 28, 2009 | 07:50 PM
oh1vette's Avatar
oh1vette
If ya email them they'll send ya pics, here's what i got, although with your car the chrome will probably look I think they have the chrome ones too....
Old Sep 29, 2009 | 12:15 AM
killerREDvette's Avatar
killerREDvette
the 30-40HP i'm talking about are the true difference of an intake that places the air intake filter inside the engine compartment (stock, blackwing) and one that uses air from outside engine compartment (vararam,honker).
SO if u have your filter using under hood air and u got to a dyno day and to two pulls...have them close the hood for one dyno pull you will see 30-40hp drop just from the engine heat. now on a dyno your hood it up so the hood is not holding in the heat and cars on dyno pulls are warmed up but not hot. and as you know hot air is bad for HP.
So for all intent and purposes the intakes like the vararam and honker use pressurized air from out side engine bay can use air that's easily 200 degree's cooler than air from under your hood during normal driving conditions which u know cold air is easier to compress in to a piston with more fuel which means MORE HP!!!!
not gonna lie im a bit more for the honker i mean i've never seen callaway make anything i didn't like and like i said our car has over 200 dyno pulls on it and has had extensive testing at Atlanta drag way and silver dollar with like air conditions with every intake said here and ones like the honker, vararam, and cyclone were much better than ones that used "engine bay air" (they stood out more when hood closed of course, but who drives with hood up?)
Old Sep 29, 2009 | 12:25 AM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
I could feel the diff with my VR B2!
Old Sep 29, 2009 | 08:36 AM
4SFED Z's Avatar
4SFED Z
Originally Posted by Jhonathan_W
Vararam all the way!
http://www.shop.jwmotoring.com/produ...&categoryId=27
Contact me for a shipping quote to you.
Those cone type intakes just don't provide the power you feel once you install the VR. I used to have one.
If you're worried about the large amounts of trash install some Z06 screens. Vetteshop (forum vendor) has the best replicas for a good price.
VARARAM. Only one that is proven on the track. Might not see a lot of results on the dyno, but its because this one is truly a ram air
Old Oct 30, 2009 | 02:15 AM
Choreo's Avatar
Choreo
I have the Hurricane as well - works great - cleaning filter is a royal PITA...
Old Oct 30, 2009 | 08:01 AM
  #33
gorghamak's Avatar
gorghamak
St. Jude Donor '10-'11-'12-'13-'14
black wing
Old Oct 30, 2009 | 08:30 AM
  #34
65convt's Avatar
65convt
Originally Posted by blacksedan87
WOW!! 30-40HP from just an intake? Which one does that? I gotta get me one of those!
Maybe if you add Longtubes, x pipe and a tune
Old Oct 30, 2009 | 08:05 PM
  #35
C5XTASY's Avatar
C5XTASY
30-40rwhp, as measured by a dyno, is a hell of a lot of power for an intake change. Air under a hood isn't exactly stagnent, except when you're not moving.
Ed
