AA Exhaust Modification
Old Sep 29, 2009 | 07:58 AM
VETSTYL's Avatar
VETSTYL
Default AA Exhaust Modification
Feeling pretty good right now after doing the AA mod to my exhaust this weekend Definitely a difference in exhaust note at WOT and just a little deeper at lower RPMs.
I know some catback purist may not agree but the $50 that I paid for this modification was the best bang for the buck mod to date; friend of mine did it at the local auto craft shop on base. I just supplied the pipe and he did the work.
The only problem is I fine myself putting my foot in it a little deeper now just so that I can hear it again Gas mileage is gonna suffer but hey I'm good with that
Old Sep 29, 2009 | 11:44 AM
00 Rooster's Avatar
00 Rooster
St. Jude Donor '08
cool to hear!! I really want to do this but my current garage doesn't have 220 for my welder...so I haven't done it. I started fitting a piece of pipe but that is as much progress as I've made. time for a new house with a better garage and this will get done.
Old Sep 29, 2009 | 03:36 PM
Nothing wrong with getting the sound you want at a really good price. Congrats on a mod to your car.
Old Sep 29, 2009 | 04:06 PM
#1 Moses's Avatar
#1 Moses
Hey vetstyl Thanks for your service to our country. Im glad you diggin the new sounds of your exhaust.
Old Sep 29, 2009 | 04:16 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Sweeet! Did you happen to shot any pictures of the mod?
Thanks,Matt
Old Sep 29, 2009 | 05:21 PM
VETSTYL's Avatar
VETSTYL
Default Pictures
Thanks,Matt
Many, many posts on the forum; do a search. If you can't find anything send me an address and I can email you some stuff.
Old Sep 29, 2009 | 07:19 PM
Old Rotor Head's Avatar
Old Rotor Head
Great low cost mod. I ran them for 3 years before I ponied up for Borla's than Ti's. Still have them in the shed
Old Sep 29, 2009 | 08:05 PM
ROJO99's Avatar
ROJO99
Great mod I think and so much better than a Catback. I have a H/C setup and the car really sounds good at WOT. I think a Catback would make my car Too loud so this is a good middle ground and so much cheaper.
Old Sep 29, 2009 | 08:24 PM
doug doo wop's Avatar
doug doo wop
So what is an AA exhaust mod?
Old Sep 30, 2009 | 09:15 PM
ROJO99's Avatar
ROJO99
A&A exhuast mod = The reverse flow muffler has three pipe openings, one inlet and two exhaust. Bye adding a short length of tube between the inlet and the closest outlet pipe you allow a portion of the exhaust to bypass the muffler exiting straight out the connected outlet pipe. This in theory increases flow escpicialy under higher loads. I have significantly more carbon build up on the outlet pipe that has the bypass attached, so there must be some benefits. No dyno proof on any improvements.
Old Sep 30, 2009 | 09:43 PM
Luster's Avatar
Luster
That's an excellent, one paragraph explanation.
Old Sep 30, 2009 | 09:56 PM
RedC5's Avatar
RedC5
Awesome mod for the price....here's a quick clip of mine.
Old Feb 12, 2010 | 08:34 PM
317nathan's Avatar
317nathan
just did aa mod, took one day, hard to get the exhaust out from under the car. Sounds great at speed, not much change at idle
Old Feb 12, 2010 | 08:40 PM
ALLEGRO's Avatar
ALLEGRO
I did this too a couple of years ago. Here is a pic before I painted
BUT......then I just had to have more, so I went the route of DMH cutouts.......NOW I AM HAPPY
Old Feb 12, 2010 | 09:07 PM
doug doo wop
Please explain these cutouts, like the cost and how long does it take to install, and where to get them. Is this controlled by a switch and I assume this means it's straight exhaust and very loud? Thanks
Old Feb 12, 2010 | 09:16 PM
ALLEGRO's Avatar
ALLEGRO
I chose the low-profile DMH units ($400) and had them installed locally in MEM for about $300.
They are switch-operated, can be closed, open or anywhere in-between. I have my switch mounted on the console between the shifter and the ride-select
The best part about cutouts is this; you can have all the quietness of OEM when on the highway or can set off car-alarms at will. I find for most of my driving that just barely open is best.
To AA Exhaust Modification
