[Z06] Brake fluid flush, how much do I need?
Old Oct 2, 2009 | 03:53 PM
BoilerUp's Avatar
BoilerUp
Default Brake fluid flush, how much do I need?
I'm planning on heading to my first HPDE later this month and wanted to flush out the stock fluid and put in some ATE SuperBlue or Motul 600. So how much do I need to buy? Thanks
Old Oct 2, 2009 | 04:25 PM
AU N EGL's Avatar
AU N EGL
two quarts. and Good DOT 4 brake fluid will do.
not quite one to flush, then the other to put in the MC
Rember for HPDE use, only fill 3/4 full. NOT to the full line
brake fluid expands when heated
Good Luck
Old Oct 2, 2009 | 04:59 PM
AlwaysInBoost's Avatar
AlwaysInBoost
I would buy a few bottles just to keep around but you will be able to flush your brakes with one bottle of Motul. You don't however have to use that stuff for the clutch res (its too expensive), I've found a GOOD dot4 fluid like Castrol LMA is great for that.
Old Oct 2, 2009 | 05:35 PM
KCvetteowner's Avatar
KCvetteowner
Remember you will want to flush the fluid BEFORE and AFTER your HPDE...
Have fun and be safe....
Old Oct 4, 2009 | 07:32 AM
AntonioZ06's Avatar
AntonioZ06
I used a little less than a quart when I flushed mine earlier this year, if it makes any difference, I have goodridge stainless braided brake lines. I expected to do a few hpde courses, so I just bought a case of 10 ATE Super Blue with free shipping (i forget where I found it)
It'll end up being cheaper in the long run. I'm going to use it in the clutch too as well
Old Oct 4, 2009 | 07:57 AM
AU N EGL's Avatar
AU N EGL
good Choice
Yes you will use a lot of fluid for the brakes and clutch
Old Oct 4, 2009 | 12:40 PM
JRitt@essex's Avatar
JRitt@essex
Supporting Vendor
We're having a special on AP Racing brake fluid right now. If you buy three bottles, you get a free bleeder bottle. AP Super 600 is comparable to Motul RBF600, and AP PRF is more similar to Castrol SRF. Both of these AP fluids are DOT approved, and extremely popular in professional racing. They are perfect for street/HPDE use.
http://www.essexparts.com/
To Brake fluid flush, how much do I need?
