Fuel Gauge Empty With a Twist
Old Oct 7, 2009 | 11:20 AM
DeeGee's Avatar
DeeGee
Originally Posted by rebelheart
Maybe since you never let the tank get down to 1/4 you have a sulfer build up on that area of the contact sweep.
That could indeed be it. On that basis, those of us with weekend cars may be better leaving the tank with lower contents leaving the sensors dry.
Or even better. Use the car more often and slosh that gas around the tank
Oh and run Techron through regularly.
Old Oct 7, 2009 | 11:53 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I had the same issue on my '99 for a long while. Techron wouldn't quite do it to solve the issue. Finally, I had the dealer update the firmware that I specified from their TIS website. Problem vanished. http://tis2web.service.gm.com/tis2web
Old Oct 8, 2009 | 01:16 AM
DeeGee's Avatar
DeeGee
Missed that tip on your first post Dave. Thanks
Now if it happens again, how to find a dealer here who has the knowledge to do the job?
Old Oct 8, 2009 | 10:48 AM
Thankfully I haven't had the erratic gas gauge problem on my last two C5s. On my '99 I had it and it seemed like it would occur at just about any fuel level. Dealer replaced the sending units under warranty and never had the problem again.
Old Oct 8, 2009 | 03:31 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
while it may not be the problem in this case, remember that the C5 has 2 fuel tanks and that they are connected and equalized with a pump. if all of a sudden your "range" seems to be about half of what it is it could also be a fault of that system. it fails to equalize the tanks and could be the cause of the gauge dropping off the charts all of a sudden.
hopefully it is something simple like a stuck sender, but unfortunately, there are other causes also.
Old Oct 8, 2009 | 03:37 PM
DeeGee's Avatar
DeeGee
Thanks but I'm happy with how it works. The pump's in the right tank and low fuel registers when its low on the left. This is a sender snag
Old Oct 8, 2009 | 05:02 PM
redrckt97's Avatar
redrckt97
would that update reflash the PCM and screw up my custom tune??
Old Oct 8, 2009 | 08:25 PM
dgrant3830's Avatar
dgrant3830
Yes it would. So, just copy out the tune changes, update the firmware, then put the tune changes back in...that's what I did
