my brother broke the left output shaft this weekend anyone replaced one and give a little info on what to remove i can do the job just need a little help on what to take apart i found the write up on how to replace the shaft was not looking forward to that but it is only nuts and bolts
Research how to fix the leaky butt on the left side.
If you replace the o-ring on the left side of the differential, you need to pull out the left output shaft.
Pulling the shaft is not bad at all.
I retorqued the lower left ball joint last weekend after doing the leaky butt on the left side.
In order to get access to the lower ball joint you have to pull the output shaft (at least the side at the wheels).
Its about a 1/2 day start to finish if you are slow and drinking beer.
While you have the shaft out, I threw some never-seize on the splines at the wheel side of the axle. It made things a lot easier pulling it out the second time!
[QUOTE=AlexSmith;1571746078]Sounds like he is the one that should be fixing it, not you. How exactly was he driving to do that?
-Alex[/QUOTE he is not a mechanic i am was just looking for some help so i did not have to pull the diff. but u have to pull the diff. to do the job. not to hard aready completed the repair. he broke it at the drag strip 4000 rpm clutch drop and bang it broke and it was aready a harden output shaft. his job is painting cars and breaking them so i can fix them he never learns
not the axle the output shaft in the diff. you have to take it apart to do the job but was not that big of a job for me
Nice job!, on the fix. Lots of work required to fix a broken shaft. That's just the way these cars are designed, that peticular break just so happens not to be a (Quick Fix). Which post or thread did you use for help? Which vendor did you use foe replacement shaft?
i work at a gm dealer as a mechanic so i used our si info i have had this car apart from on end to the other complete motor to clutch replacement we got lpe harden output shaft did not know it had already one installed and that is the one it broke we aready had part on the way or we would have used a different brand they told us they had a new supplier making thier shafts now and it did look differnnt so we used it and hoping for the best
