P0410 code frustration! Any advice?
Old Oct 10, 2009 | 08:25 PM
Ryan040675's Avatar
Ryan040675
Default P0410 code frustration! Any advice?
My 2000 recently started throwing the popular P0410 secondary injection system mafunction code. I did several searches on this board for advice and tried a few things. Here is what I've done:
-Pulled the battery and tray and inspected the vacuum lines. No breaks found.
-Vaccuum tested the line that runs over to the injection pump across the front bumper and found no detectable leak.
-I disconnected the pipe joint next to the alternator while running and found a strong stream of air running out, so the pump IS working.
-All vacuum driven HVAC controls are working correctly.
The only thing I could find that looked suspicious was a little solenoid connected to a pair of vacuum lines under the battery amongst the various vacuum hoses.. I disconnected it and looked it over to see if it possibly had any breaks or cracks. It looked good physically so I took it off it's mount and noticed it had a little silver "plug" that slid out of the back. Inside looked kind of dirty, so I cleaned it up along with a little spring that was in there too.
I put the solenoid on an ohm meter and the resistance looked kind of high. Normally electronics I test read around 2 ohms resistance and this one was about 4.5: rolleyes: I presume this little device acts as a valve cutting vacuum off and on via PCM control. I threw some alligator clips on it and applied a little juice, but it made no click or sounds of any kind.
Does anyone out there know what this thing is called or know a part number for it? Does it seem like this is a potential cause for my 410 or am I barking up the wrong tree?
I just can't seem to find anything wrong and it's getting me
Any experience out there with this would be appreciated!
Old Oct 10, 2009 | 08:34 PM
robsc501's Avatar
robsc501
Hi Ryan;
This may help you out.
www.obd-codes.com/p0410
robsc501
Old Oct 11, 2009 | 11:02 AM
Ryan040675's Avatar
Ryan040675
Thanks Rob
I read through all of the link you gave me. Unfortunately it's more universal rather than Corvette specific. I know that icing hasn't been my problem since the weather hasbeen rather mild.
Anyone else??
Oh by the way, I found the little vacuum solenoid I described on Rockauto. I hate throwing parts at a problem but I may give it a shot.
Old Oct 11, 2009 | 11:13 AM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Remember you asked...lol
9/10 times it's just a bad gas cap
Here you go...
DTC P0410 Secondary Air Injection (AIR) System
Object Number: 383940 Size: MF
Click here for detailed picture of above image.
Circuit Description
An AIR pump is used on this vehicle to lower tail pipe emissions on start-up. The PCM supplies a ground to the AIR pump relay, which energizes the AIR pump.
The PCM monitors the HO2S voltages to diagnose the AIR system.
During the AIR test, the PCM activates the AIR pump during closed loop operation. When the AIR is activated, the PCM monitors the HO2S voltages and short term fuel trim values for both banks of the engine. If the AIR system is operating properly, the HO2S voltages should go low and the short term fuel trim should go high.
If the PCM determines that the HO2S voltages for both banks did not respond as expected during the tests, DTC P0410 sets. If only one sensor responded, the PCM sets either a DTC P1415 or P1416 to indicate on which bank the AIR system is inoperative.
Conditions for Running the DTC
* DTCs P0101, P0102, P0103, P0107, P0108, P0112, P0113, P0117, P0118, P0125, P0171-P0175, P0200, P0300, P0335, P0336, P0351-P0358, P0440, P0442, P0443, P0446, P0449, P1120, P1220, P1221, P1258, P1441 and HO2S DTCs are not set.
* The engine is running for greater than 2.0 seconds.
* The maximum air flow is 22 g/s.
* The Air Fuel ratio is 14.7:1
* The engine load is less than 40%.
* The ignition voltage is greater than 11.7 volts.
* Engine is not operating in Power Enrichment, Decel Fuel Shut-off, or Catalyst Over-temperature Modes.
* The engine is operating in closed loop for greater than 15 seconds.
* The engine speed is greater than 725 RPM.
* The ECT is greater than 80°C (176°F) but less than 110°C (230°F).
* The IAT is greater than -10°C (-14°F).
* The fuel system is operating in fuel trim cells 1, 2, 4, 5, or 6
Conditions for Setting the DTC
The HO2S voltage does not go below 222 mV for 1.2 seconds, when the AIR pump turns ON during closed loop operation.
OR
The short term fuel trim does not change more than a predetermined value, when the AIR pump turns ON during closed loop operation.
Action Taken When the DTC Sets
* The PCM illuminates the malfunction indicator lamp (MIL) on the second consecutive ignition cycle that the diagnostic runs and fails.
* The PCM records the operating conditions at the time the diagnostic fails. The first time the diagnostic fails, the PCM stores this information in the Failure Records. If the diagnostic reports a failure on the second consecutive ignition cycle, the PCM records the operating conditions at the time of the failure. The PCM writes the conditions to the Freeze Frame and updates the Failure Records.
Conditions for Clearing the MIL/DTC
* The PCM turns OFF the malfunction indicator lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
* A last test failed, or current DTC, clears when the diagnostic runs and does not fail.
* A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.
* Use a scan tool in order to clear the MIL and the DTC.
Diagnostic Aids
Important
* Remove any debris from the PCM\TAC module connector surfaces before servicing the PCM\TAC module. Inspect the PCM\TAC module connector gaskets when diagnosing/replacing the modules. Ensure that the gaskets are installed correctly. The gaskets prevent contaminate intrusion into the PCM\TAC modules.
* For any test that requires probing the PCM or a component harness connector, use the Connector Test Adapter Kit J 35616-A . Using this kit prevents damage to the harness/component terminals. Refer to Using Connector Test Adapters in Wiring Systems.
AIR Pump Relay Underhood Electrical Center Terminal Identification
Front of Vehicle
Left Side of Vehicle
Ignition
B+
Right Side of Vehicle
Load
Control
AIR Solenoid Relay Underhood Electrical Center Terminal Identification
Front of Vehicle
Ignition
Load
B+
Control
* Using Freeze Frame and/or Failure Records data may aid in locating an intermittent condition. If you cannot duplicate the DTC, the information included in the Freeze Frame and/or Failure Records data can aid in determining how many miles since the DTC set. The Fail Counter and Pass Counter can also aid determining how many ignition cycles the diagnostic reported a pass and/or a fail. Operate the vehicle within the same freeze frame conditions (RPM, load, vehicle speed, temperature etc.) that you observed. This isolates when the DTC failed.
* For an intermittent, refer to Symptoms .
Test Description
The numbers below refer to the step numbers on the diagnostic table.
2.
If DTCs P0412 or P0418 are set, diagnose those DTCs first.
4.
This step is testing for battery voltage at the AIR pump relay and the AIR solenoid relay. If voltage is not present at both of the AIR relays the AIR system does not operate properly.
5.
The scan tool offers three modes of AIR operation, AIR solenoid, AIR pump, and AIR system. Use the AIR system selection when commanding the AIR pump, or relays. This mode ensures that the entire AIR system is responding to the scan tool commands. If DTCs P0412 or P0418 are not set and the relays do not respond to the scan tool commands, inspect for excessive resistance in all of the circuits associated with the AIR system.
6.
This step is testing for power to the AIR pump.
7.
This step is testing the ground circuit for the AIR pump.
10.
A restriction in a hose or pipe before the systems divides will cause this DTC to set. Inspect for kinks or blockages from the AIR pump to the connection point where the AIR system divides.
12.
This step is testing for a grounded circuit between the AIR pump and the AIR pump relay.
13.
This step is testing for a grounded circuit between the AIR pump and the AIR solenoid relay.
DTC P0410 - Secondary Air Injection (AIR) System
Step
Action
Value(s)
Yes
No
1
Did you perform the Powertrain On-Board Diagnostic (OBD) System Check?
Go to Step 2
Go to Powertrain On Board Diagnostic (OBD) System Check
2
Are DTCs P0412 and/or P0418 set?
Go to Applicable DTC table
Go to Step 3
3
Is the AIR pump fuse OK?
Go to Step 4
Go to Step 11
4
1. Turn OFF the ignition.
2. Disconnect the following components:
* The AIR pump relay.
* The AIR solenoid relay.
3. Probe both relay B+ supply circuits at the underhood electrical center using the test lamp J 34142-B connected to ground. Refer to Diagnostic Aids for terminal identification.
Does the test lamp illuminate for both terminals?
Go to Step 5
Go to Step 16
5
1. Install both relays.
2. Turn ON the ignition leaving the engine OFF.
3. Enable the AIR system using a scan tool.
Does the AIR pump turn ON?
Go to Step 8
Go to Step 6
6
2. Disconnect the AIR pump electrical connector. Refer to Secondary AIR Injection Pump Replacement .
3. Probe terminal A of the AIR pump electrical connector using the test lamp J 34142-B connected to battery ground. Refer to Probing Electrical Connectors in Wiring Systems.
4. Turn ON the ignition leaving the engine OFF.
5. Enable the AIR system using a scan tool.
Is the test lamp illuminated?
Go to Step 7
Go to Step 17
7
Probe terminal C of the AIR pump electrical connector using the test lamp J 34142-B connected to B+.
Go to Step 25
Go to Step 18
8
2. Disconnect the AIR pump outlet hose from the AIR pump. Refer to Secondary AIR Injection Pump Replacement .
3. Turn ON the ignition.
4. Enable the AIR pump using a scan tool.
Is air flow present at the AIR pump outlet?
Go to Step 10
Go to Step 9
9
3. Probe terminal B of the AIR pump electrical connector using the test lamp J 34142-B connected to battery ground. Refer to Probing Electrical Connectors in Wiring Systems.
Go to Step 25
Go to Step 19
10
1. Inspect for a restriction/blockage or a disconnect in the AIR hoses/pipes between the AIR pump and the point where the system branches to both sides of the engine.
2. If you find a restriction/blockage or a disconnect in the AIR hoses/pipes, repair as necessary.
Is the action complete?
Go to Step 27
11
3. Probe both relay B+ supply terminals at the underhood electrical center using the test lamp J 34142-B connected to B+. Refer to Probing Electrical Connectors in Wiring Systems. Refer to Diagnostic Aids for terminal identification.
Go to Step 20
Go to Step 12
12
1. Disconnect the AIR pump electrical connector. Refer to Secondary AIR Injection Pump Replacement .
2. Probe the AIR solenoid relay load terminal at the underhood electrical center using the test lamp J 34142-B connected to B+. Refer to Diagnostic Aids for terminal identification.
Does the test lamp illuminate?
Go to Step 21
Go to Step 13
13
Probe the AIR pump relay load terminal at the underhood electrical center using the test lamp J 34142-B connected to B+. Refer to Diagnostic Aids for terminal identification.
Go to Step 22
Go to Step 14
14
1. Install the AIR pump electrical connector.
2. Install a new fuse.
3. Install the AIR pump relay.
5. Enable the AIR system using the scan tool.
Does the fuse open?
Go to Step 26
Go to Step 15
15
1. Install the AIR solenoid relay.
2. Enable the AIR system using the scan tool.
Does the fuse open?
Go to Step 26
Go to Diagnostic Aids
16
Repair the open circuit that did illuminate the test lamp. Refer to Wiring Repairs in Wiring Systems.
Go to Step 27
17
1. Test for continuity of the circuit between the AIR pump electrical connector terminal A and the AIR pump relay using the DMM J 39200 . Refer to Testing for Continuity in Wiring Systems.
2. If you find an open circuit repair the circuit as necessary. Refer to Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step 27
Go to Step 23
18
Repair the faulty ground connection or open AIR pump ground circuit. Refer to Wiring Repairs in Wiring Systems.
Go to Step 27
19
1. Test for continuity between the AIR pump electrical connector terminal B and the AIR Solenoid relay using the DMM J 39200 . Refer to Testing for Continuity in Wiring Systems.
Go to Step 27
Go to Step 24
20
Repair the short to ground in the ignition feed circuit between the fuse and the relays. Refer to Wiring Repairs in Wiring Systems.
Go to Step 27
21
Repair the short to ground in the circuit between the AIR Solenoid relay and the AIR pump. Refer to Wiring Repairs in Wiring Systems.
Go to Step 27
22
Repair the short to ground in the circuit between the AIR pump relay and the AIR pump. Refer to Wiring Repairs in Wiring Systems.
Go to Step 27
23
Replace the AIR pump relay. Refer to Secondary Air Injection Pump Relay Replacement .
Go to Step 27
24
Replace the AIR solenoid relay. Refer to Secondary Air Injection Solenoid Relay Replacement .
Go to Step 27
25
1. Inspect for poor connections at the AIR pump electrical connector. Refer to Intermittents and Poor Connections Diagnosis in Wiring Systems.
2. If you find a poor connection repair the terminal as necessary. Refer to Repairing Connector Terminals in Wiring Systems.
Go to Step 27
Go to Step 26
26
Replace the AIR pump. Refer to Secondary AIR Injection Pump Replacement .
Go to Step 27
27
1. Select the Diagnostic Trouble Codes (DTC) option and the Clear DTC Information option using the scan tool.
2. Idle the engine at the normal operating temperature.
3. Select the Specific DTC option under the Diagnostic Trouble Code (DTC) option using a scan tool.
4. Operate vehicle within the Conditions for Running this DTC as specified in the supporting text, if applicable.
Does the scan tool indicate that this test failed?
Go to Step 2
Go to Step 28
28
Select the Capture Info option and the Review Info option using the scan tool.
Are any DTCs displayed that you have not diagnosed?
Go to the applicable DTC table
System OK
Document ID# 316832
Peace
Chip
__________________
..................Click for
Old Oct 11, 2009 | 08:51 PM
robsc501's Avatar
robsc501
Hi Ryan;
I would do as Willfulone suggested & replace the gas cap.Then reset & see if the code disappears. Heres a simple test: Start the car cold , the air pump should come on then pull the hose off at the check valve on the drivers side ( at #7 cylinder).If you feel air coming out you may have a stuck or bad check valve.If you do not feel any air take a look at the hose running from the a/pump to the shut off valve. Check it for being kinked or if there is blockage.Do this test on the left side.If you can not find the problem then pay the money to Lawrence Chevrolet to connect the tech 2. They will be able to tell you the problem very quickly, then you can do the repair your self.With all the humidity( in summer) around this area I would suspect a stuck one way check valve or a lazy o2s.
robsc501
To P0410 code frustration! Any advice?
