Steering wheel decal
Old Oct 11, 2009 | 09:32 AM
Florida Mike's Avatar
Florida Mike
Default Steering wheel decal
Anyone with a wheel decal have a secret to getting them to stick? I cleaned it with alcohol ahead of time but its really hard to get them to stick to that material.
Would heating with a hair dryer help to get it to bend to the contours?
Old Oct 11, 2009 | 09:57 AM
Shirl's Avatar
Shirl
2025 C8 of the Year Finalist - Modified
2021 C7 of the Year Finalist - Unmodified
The one I have came with a primer liquid. I cleaned it with alcohol first and then applied the primer liquid stuff (3m makes it) and put it on. It doesn't budge.
Old Oct 11, 2009 | 10:23 AM
jrose7004's Avatar
jrose7004
I cleaned mine completely with denatured alcohol, let it dry, used rubber gloves and tweezers and it's stayed on for over 2 years now.
Old Oct 11, 2009 | 10:32 AM
Florida Mike
Hmmm? I cleaned the wheel but it hasn't laid down flat and stuck to the surface. WHat a PITA!
Old Oct 11, 2009 | 10:44 AM
c5vetteguy's Avatar
c5vetteguy
2018 C5 of Year Finalist
What type of decal did you get? Perhaps the glue on it is not up to snuff. If you don't have the Cyberdine 3D, get it! They're the best.
http://www.vetteworksintl.com/Cyberdine1.html
Old Oct 11, 2009 | 08:25 PM
atmsrus1's Avatar
atmsrus1
I had a hood liner decal that did the same thing, I bought some 3M spray adhesive and put it on the decal and then used a hair dryer and it worked great
Old Oct 11, 2009 | 10:34 PM
widewheel's Avatar
widewheel
The Cyberdine instructions say to use a good quality dishwashing detergent and a tooth brush and scrub the area two or three times where the 3D decal goes. Rinse completely after every scrubbing. This is how I did mine and so far they have lasted perfectly through the hot Oklahoma summer. It is expensive but 3M makes what they call Press-In-Place Emblem Adhesive. I've never used it but was reading about it on the 3M website.
Old Oct 11, 2009 | 10:59 PM
Florida Mike
It just seems like the tricky part is that its not a flat surface. The flat parts of the "flags" have set down fine but the circle parts of that thin area on the "pointed" part below have not.
Oh well, it was only $16. I can't take it up now without tearing or stretching it yet not all is stuck down. Typical for my luck.
Old Oct 12, 2009 | 10:42 AM
widewheel's Avatar
widewheel
I got mine from the Cyberdine store on fleabay. It's the flags only raised decal. I didn't have to worry about it sticking to the halo.
Old Oct 12, 2009 | 11:03 AM
RSuperfreak3's Avatar
RSuperfreak3
Mine is a cyberdine as well from the "great auction site"! No issues with sticking. I did use laundry detergent and a toothbrush and cleaned it really good. Test the area with a piece of scotch tape first. If that sticks your golden...if not...keep cleaning!
Old Oct 12, 2009 | 12:36 PM
robsc501's Avatar
robsc501
Hi There;
Any pics of the chrome or gold 3d decal on the s/ wheel & the a/bag/
robsc501
To Steering wheel decal
