power source.
Old Oct 13, 2009 | 11:33 AM
bucwheat's Avatar
bucwheat
Default power source.
Hey guys,I routed a power wire from my Radar at the top of my windshield into the drivers footwell and can't find a power source to tap into,anyone know of a power wire I can tap that is only on with the key on.And yes I had the pigtail that went to the mirror,didn't work worth a crap.
Old Oct 13, 2009 | 11:11 PM
c5blkvetteguy's Avatar
c5blkvetteguy
Look in the passenger footwell. There is a black plug with hot, ign, and ground.
Old Oct 13, 2009 | 11:16 PM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Did you blow fuses? I had one and I kept blowing fuses with it installed in the mirror.
Old Oct 13, 2009 | 11:27 PM
jrprich's Avatar
jrprich
Usually found in the upper left corner as you look at the fuse box.
Old Oct 14, 2009 | 03:23 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
Usually wrapped in Black tape...
Old Oct 14, 2009 | 08:58 AM
DeeGee's Avatar
DeeGee
The guys are spot on
You have a couple of options to get an additional switched acc power source
The easiest is to use fuse #22 which is live but not used for any other function. I used an “add a circuit” connector to hook in. This gives you the switched hot.
These are not my pics but show you the hook ups
You can see how the connectors slot into the fuse box/
The other option is to hook up into the spare connector which is available for ancillary devices. I believe this is used for the CD changer so it may not be an option for you if you have one of those fitted.
In the passenger footwell (unless you have a 2004) behind the kick board you’ll see a fuse block and to its left a silver box which is the BCM. There are three wires taped together feeding into a connector.
The Black wire is ground; the Orange wire is powered through fuse #7 but is permanent hot. The Yellow wire is powered through fuse #11 and is switched hot when the key is in the ACC or ON positions. Hook up to the Yellow for switched ACC.
Old Oct 14, 2009 | 01:53 PM
bucwheat's Avatar
bucwheat
No JW,I had trouble with the invisa cord losing power contact in the mirror,so I used a dab of silicone to hold it in place ,worked great for months until the suction cups gave way and it pulled the wires out,I couldn't get the wires back in so I bought a hard wire with a tap in for power.
Old Oct 14, 2009 | 01:55 PM
bucwheat's Avatar
bucwheat
Thanks Dave ,that's the info I needed.
Old Oct 15, 2009 | 10:54 AM
bucwheat's Avatar
bucwheat
Got it done, easy job when you have help,thanks guys.
Old Oct 15, 2009 | 10:59 AM
DeeGee's Avatar
DeeGee
No trouble
Old Oct 15, 2009 | 11:00 AM
JW Motorsports
Banned Scam/Spammer
Good deal!
Old Oct 16, 2009 | 08:43 AM
j84buick's Avatar
j84buick
Where do you find these? I checked the local auto parts stores and could not find something like this.
Old Oct 16, 2009 | 08:47 AM
bucwheat's Avatar
bucwheat
I saw them at Auto Zone,around 6 bucks.
Old Oct 16, 2009 | 03:41 PM
Jistari's Avatar
Jistari
Yup, nice clean way to add power to something.
They even have them configured with two fused positions, one where you place the fuse you pull to insert the fuse tap (that protects the original circut) and another recepticle on the holder to put a fuse to protect the circut you're running.
If either blows you would still retain the other circut.
To power source.
