storage for the winter
Old Oct 13, 2009 | 09:52 PM
DMan 01''s Avatar
DMan 01'
Default storage for the winter
I am about to put the vette away for the winter I was not happy with the charger I had hooked up all winter last year. Any suggestions for a charger for winter storaqe? I am in NE Ohio and the car is kept under cover in an unheated garage. Like to hear pros and cons of different types.
Old Oct 13, 2009 | 10:51 PM
MNCrystalRed2011's Avatar
MNCrystalRed2011
I have used a Deltran Battery Tender for the last 6 years. I think you will likely find a lot of forum members use one. It is not a charger, but a battery maintainer. It will slowly bring the battery up to full charge then keep it there and not overcharge it.
Old Oct 13, 2009 | 10:55 PM
LTC Spivey's Avatar
LTC Spivey
This will be my frist winter with my C5, and also looking for some tips on storage. Can I just keep it in my garage uncovered.
Old Oct 13, 2009 | 10:56 PM
itzza427's Avatar
itzza427
C-Tech is another popular one,,and is more versatile. Supposed to be able to float/maintain,,and do a full charge and if I am not mistaken has a pulse setting that is supposed to revive some dead batteries!! Does cost more though!! could do what I do,,drive it through the winter,,just leave her in on the bad days!!
Old Oct 13, 2009 | 11:04 PM
MNCrystalRed2011
I kept mine uncovered the first winter, but have used a custom cover ever since. Just too hard to see the beautiful electron blue coupe sit there all winter. At least looking at it now with a gray cover on it is easier to take until spring.
Old Oct 13, 2009 | 11:08 PM
korte's Avatar
korte
yeah, this is a hard time to be selling. People don't drive corvettes in the winter.
Old Oct 13, 2009 | 11:11 PM
pcbunn's Avatar
pcbunn
I've used Schumacher brand battery tenders for years. I have 6 of them on various vehicles permantly installed on each except my motorcycle and daily driver. On those I share one. I have one mounted directly above the battery on my '01Z which I keep pluged in continuously during the winter. The battery in my Z is going on 7 years old and shows no indication of deterioration. It is a floating 1.5amp tender and costs about $30.00. Check them out on the internet for addtional information.
Old Oct 14, 2009 | 01:11 AM
lh4x4's Avatar
lh4x4
Never use a charger. Use a maintainer. The 1.5 amp Schumaker at Wally World for $20 is good. I have 12 of them in use for many years. I have even drove over one once:bb.
The best use of a maintainer is to use it daily. Unplug when you leave the garage and plug back in upon returning.
I sold a motorcycle this year with the original eight year + battery still going strong. A motorcycle battery is generally a 2 to 3 year life.
Put StaBil in the tank and drive around a little until it is mixed and through the injectors. I used to put covers on mine but then I can't look at them when I have my morning coffee.
Old Oct 14, 2009 | 08:39 AM
j84buick's Avatar
j84buick
Mine went to sleep in the garage last week. A couple weeks early since the weather has suddenly turned for the worse. This is my fall traditon:
1) Change Oil (my preference to do it in the fall each year).
2) Make sure the tires are inflated to 30psi in the colder weather.
3) A bunch of little stuff like treating the weather stripping and lubricating the hinges.
4) Full detail inside, out and underneath.
5) Stabil in the gas tank and a trip to the gas station to fill it up.
6) Escort 8500 moved to daily driver
7) Battery tender installed.
8) Covered.
It's a bittersweet day but I look forward to it every year. A fall tradition for me. The really neat thing about storing the C5 is how fast it is in the spring. It's like getting a new car.... every year!
Old Oct 14, 2009 | 08:50 AM
charlene's Avatar
charlene
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13
I keep mine in the garage covered up and hooked up to a battery tender plus.That is what you have to do.If you leave the vette uncovered for 5 or 6 months through the winter the car will be so dusty from you opening and closing the garage door.
Old Oct 14, 2009 | 08:51 AM
charlene's Avatar
charlene
Battery tender plus a cover and a bottle of sta-bil in your full gas tank and you will be set.
Old Oct 14, 2009 | 09:16 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
The C-Tek 3300 is an excellent battery tender. I usually change the oil, detail the car and fill up the gas tank (less air, less moisture). I also try to find a couple of winter days when the roads are clear and dry and give the cars some exercise.
Old Oct 14, 2009 | 02:28 PM
99 hardtop 08's Avatar
99 hardtop 08
Default winter blues
Some pros will tell you to drive the car, I have already had a differential seal leak on the drivers side so I have been trying to drive it on days that the roads are good. When it's time to leave this green earth, you're probably not going to be thanking yourself for never driving your Vette. Get out and enjoy it charge that battery with your right foot! Save the wave!
P.S. I do use sea foam for a fuel stabilizer.
Old Oct 14, 2009 | 02:52 PM
I've been using the Deltran Battery Tender Plus on mine for years and it works just fine. Hook it up and leave it is what I do.
Old Oct 14, 2009 | 02:57 PM
SaberD's Avatar
SaberD
just start it up every couple weeks :P. problem solved.
Old Oct 14, 2009 | 03:24 PM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
I guess I am just lucky because I live in Florida and do not have to worry about the winter and snow. What I have always wondered however is why you (all those in the north) want to put it to bed for the winter, and there is not even snow on the ground. It is only October (I know it has turned cold in spots) why put it away just because the temp. has dropped I don't understand. If you enjoy driving it, way not wait until the weatherman says SNOW tomorrow.
Old Oct 14, 2009 | 06:33 PM
charlene's Avatar
charlene
I use to do that but it got to be silly to run down to the garage every week or two to start the car up let it run for a while when all i had to do was hook that tender up cover the car and forget it for the winter.
To storage for the winter
Old Oct 14, 2009 | 06:44 PM
csexton's Avatar
csexton
Battery Tender has worked well for me
Chuck
Old Oct 14, 2009 | 07:29 PM
dobewillie's Avatar
dobewillie
I have had a black and decker tender for 3 years now no problems from Wally world 10 bucks
Old Oct 14, 2009 | 07:58 PM
Too-Fast's Avatar
Too-Fast
2024 C6 of the Year Winner - Modified
In the garage, covered, battery tender...just did it this past weekend, it was 21 degrees out. This weekend it is supposed to be mid to high 60's with loads of sunshine...go figure.
