mouse in vent
Old Oct 14, 2009 | 03:02 PM
lanny.morris's Avatar
lanny.morris
Cruising
Default mouse in vent
The weather has been bad here the past 2 weeks so I have left the Vette under the carport. Got it out the other night and when I turned on the heat the bad odor of a dead mouse hit me in the Face! Is there any device that will turn those nasty rats away! In 4 years under the carport this is the first one. The dead rat was in my fan blower.
Old Oct 14, 2009 | 03:32 PM
RSuperfreak3's Avatar
RSuperfreak3
Dryer sheets is supposed to keep mice away. I used to store my '69 Camaro for years in a pole barn and never had any mouse issues. I bought a box of dryer sheets and would put them everywhere, interior, under the hood, exhaust pipes etc. (use the whole box)! Smells better than moth *****, which is also supposed to work on mice.
Good Luck
Old Oct 14, 2009 | 03:51 PM
DeBaGo's Avatar
DeBaGo
lol, I saw this and thought "Oh God, Alex's snake got loose in the car again!"
But, yeah the dryer sheets work well on mice as well as bull ants. We have lots of bull ants here in N. FL. and that works on them.
Old Oct 14, 2009 | 08:48 PM
jrose7004's Avatar
jrose7004
Gross!
Old Oct 15, 2009 | 08:36 AM
JohnnyB's Avatar
JohnnyB
Great info about the dryer sheets. I'll give them a try.
2 years ago I found a nest under the hood of my DD. A trap caught the culprit that night. Last week, I found another nest in my DD and a deuce on top of the battery in my Corvette More traps did the job but I'm going to deploy the sheets as a defensive measure.
Old Oct 15, 2009 | 11:55 AM
Hudson's Avatar
Hudson
Also,
Cut up a bar of Irish Spring into 1/4's.
Put the blocks of soap onto tinfoil and set two in the car, one in the trunk, one under the hood.
NO MICES ALLOWED.
Jim
Old Oct 15, 2009 | 12:07 PM
Good tips. Hopefully using one or a combination of them will keep the mice out of your car.
Old Oct 15, 2009 | 12:12 PM
SeanMounce's Avatar
SeanMounce
I guess the car port would make it more of a challenge, I just put about 10 moth ***** around in my garage, keeps the car smelling fine, but the garage wreaks. They evaporate in about 2 weeks so watch them and replace when necessary.
Old Oct 15, 2009 | 03:42 PM
Dominic Toretto's Avatar
Dominic Toretto
Solution:
-Alex
Old Oct 15, 2009 | 10:53 PM
SUNNYD 95's Avatar
SUNNYD 95
Originally Posted by AlexSmith
Solution:
-Alex
If this were my car, it would be FOR SALE now!!!!!!!!!
CHEAP
Old Oct 15, 2009 | 11:18 PM
Z06ster's Avatar
Z06ster
Yes.... unfortunately it is true. C5 make great mouse habitats. I am not sure how they get in, but they love the HVAC ducting and the blower motor. I dropped my blower motor out a few years ago and there was a nice collection various seeds inside.
Old Oct 15, 2009 | 11:53 PM
intoc6s's Avatar
intoc6s
My EX-GF had a dead mouse in her HVAC ducting under her dash in her Olds Alero. It took a few days for her to get it in at the shop....... By then it was BAD!! It took awhile (and alot of Febreeze) to get that dead smell out of there.
This was b4 i was with her, otherwise i wouldve been the "lucky" one to get the rotten corpse out of there.
Old Oct 15, 2009 | 11:58 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
Solution:
-Alex
Do rent out your snake?
Place several of those sticky traps on a bunch of newspaper on the floor boards as well!
Old Oct 16, 2009 | 12:38 AM
Dominic Toretto
I like my solution
-Alex
Old Oct 16, 2009 | 06:13 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
Are you having trouble with mice or rats?
Old Oct 16, 2009 | 06:19 AM
DevilDog II's Avatar
DevilDog II
Veteran: Marine Corps
Oldtimer
Good Luck
Not to mention you don't have static cling in the spring.
Old Oct 16, 2009 | 09:13 AM
MDLIFE's Avatar
MDLIFE
Default dryer sheets
I have heard that putting the dryer sheets on top of each tire is also effective as the rodents use the tires as a ladder.
To mouse in vent
Old Oct 16, 2009 | 09:27 AM
DeBaGo's Avatar
DeBaGo
I like my solution
-Alex
+1
Alex's Automotive Rodent Removal Service
-a subsidiary of Alex's Automotive Reptile Removal Service
Old Oct 16, 2009 | 09:44 AM
Atok's Avatar
Atok
Dryer sheets seem to work well. Also, I've heard Irish Spring soap works but I haven't tried it.
Maybe worse than a dead mouse in the ducts is one living in there but trapped. That happened to my wife's car. It crapped and urinated throughout the entire system of ducts. I had to remove the interior to get the ducts out and wash everything with Javex followed by soap and water. Horrible smell!
Old Oct 16, 2009 | 09:51 AM
Dominic Toretto
Originally Posted by DeBaGo
+1
Consequently, the solution to both is to use the other
-Alex
