Tpms
Old Oct 18, 2009 | 05:20 PM
Lancejoker's Avatar
Lancejoker
Default Tpms
Anyone here(besides the Z06 guys) running without TPMS because of aftermarket wheels?
Lance
Old Oct 18, 2009 | 08:25 PM
Oldvetter's Avatar
Oldvetter
Some guys use bands and epoxy to secure their TPMSs in non-standard wheels.
There are new "holders" for TPMSs that mount in tire stem hole and will secure TPMSs.
Old Oct 18, 2009 | 08:26 PM
jrose7004's Avatar
jrose7004
I use bands on my i-Forged wheels.
Old Oct 18, 2009 | 08:30 PM
Indy's Avatar
Indy
Some people get lucky and don't get any codes, but most do. You can clear the error message, but I think it will come back when the system cycles through it's diagnostic routine...I am mounting my winter tires on my old wagon wheels without tpms this year, so I will be in the same boat as you. Cheers.
Old Oct 18, 2009 | 08:35 PM
canecorso69's Avatar
canecorso69
I am running without them. I am throwing the code for that. I just carry a tire repair kit and pump.
Old Oct 18, 2009 | 08:44 PM
JohnnyDee's Avatar
JohnnyDee
2023 C7 of the Year Finalist - Modified
2019 C5 of Year Finalist (performance mods)
2017 C5 of the Year Finalist
I'm running without sensors. Every time I start the car and it comes up I just hit reset. It throws a code after so many cycles but I just clear the code when that happens.
Old Oct 18, 2009 | 11:21 PM
Lancejoker's Avatar
Lancejoker
Thanks OldVetter. After you said that I decided to search and came across this.
http://www.iforged.com/store/index.p...61dff29241c592
I emailed them to see which application would be right for my wheels. I'd rather not deal with the code or reprogramming issue if I don't have to.
Old Oct 19, 2009 | 10:10 AM
Oldvetter's Avatar
Oldvetter
You are welcome Lancejoker. The fact that new cars came out with TPMSs has helped spur the aftermarket into accommodating TPMSs.
Remember they must be mounted close to a side of the wheel so you can use a magnet to reprogram them. You can try a magnet on them BEFORE mounting tires, to make sure they work.
Old Oct 19, 2009 | 10:37 AM
Lancejoker's Avatar
Lancejoker
Thanks for the advice. I'm just happy about not having to run without them. Some kind of secure feeling being able to look at the presure
Old Oct 19, 2009 | 10:45 AM
Dream Tire's Avatar
Dream Tire
Majority of aftermarket wheels are TPMS compatible
I would recommend using sensors just for the fact that we all use very expensive tires.
It would be like to get a warning that you have a tire going low and noticing this before the tire gets damaged beyond repair.
Without sensors, you will most likely notice a problem when it is too late.
Rod
PS, you can probably pick up a set of used sensors for around $100
Old Oct 19, 2009 | 10:51 AM
Lancejoker's Avatar
Lancejoker
Thanks Rod. The whels are an early set of CCW with 90* valvestems instead of the angled valvestems. I wasn't going to use straps. Like I said,I found those from Iforged that will hopefully work for me. I'll be buying new sensors. Used ones aren't worth saving $92 and not knowing how long they were used or how much they have left.
Old Oct 19, 2009 | 02:55 PM
mschamberger's Avatar
mschamberger
I agree. I bought a new set of TPM sensors for my winter wheels too. I just reprogram the receiver ever fall/spring when I switch out the wheels.
Old Oct 19, 2009 | 02:56 PM
All the aftermarket wheels that I have had have been able to accept the factory TPS - so I have always used them.
Old Oct 19, 2009 | 03:13 PM
Dream Tire's Avatar
Dream Tire
Im basing this from Canada...
4 sensors here from the dealer cost 500$
If they are 200 for a new set, then definitely new is the way to go.
Rod
Old Oct 19, 2009 | 03:16 PM
Lancejoker's Avatar
Lancejoker
Hey Rod,Gene Culley sent me a message on another thread. $192.90 for the set. Much better way to go in my opinion.
Old Oct 20, 2009 | 01:47 PM
cadguymark's Avatar
cadguymark
have driven over 14K miles without, including two trips out west, DIC says service TPMS system occasionally, my original tires sit next to car in garage so car is happy first ~50 miles from home
does not affect handling
BTW, this shows the corvette tax http://www.americanmuscle.com/tpms-tool.html
Old Oct 20, 2009 | 02:22 PM
Lancejoker's Avatar
Lancejoker
You can use a magnet.
Old Oct 20, 2009 | 09:57 PM
cadguymark's Avatar
cadguymark
not on a C6
Old Oct 20, 2009 | 11:13 PM
Lancejoker's Avatar
Lancejoker
Yeah.Tough break for you C6 guys on that one.
To Tpms
