tpms trick pcm
Old Oct 20, 2009 | 12:12 PM
clif's Avatar
clif
St. Jude Donor '09-'10
I personally LOVE my TPS sensors! Without a spare OR RunFlats, I want to know if I have a slow leak, or worse!
Old Oct 20, 2009 | 01:01 PM
Lancejoker's Avatar
Lancejoker
Wicked, why don't you like them?
Old Oct 20, 2009 | 01:16 PM
Wicked C5's Avatar
Wicked C5
St. Jude Donor '04
They turn into a big PIA on cars like ours that are getting older. If you want to go drag racing and lower your pressure they give you a warning. They fail sometimes without warning after all most cars are between 8-10 yo
I don't ever use run flats but I carry Fix a flat just in case. If you use it the sensor is destroyed.
Old Oct 20, 2009 | 01:30 PM
Lancejoker's Avatar
Lancejoker
You can use Slime. It's sensor safe. I like them. I'll use them as long as the car I'm driving has the option for it.
Old Oct 20, 2009 | 01:50 PM
RyanR0101's Avatar
RyanR0101
Originally Posted by Mark C5
They go inactive when not turning to preserve battery life. From the service manual:
"When the vehicle is stationary the sensors internal roll switches are open, which puts the sensors into stationary mode. In this mode the sensors transmit once every 60 minutes. As vehicle speed increases, centrifugal force closes the sensors internal roll switches, which puts the sensors to go into drive mode. In this mode the sensors transmit once every 60 seconds."
I just rebuilt 2 of my sensors to put new batteries in and put my autocross, non TPS equipped wheels/tires on while doing so. Driving along with the TPS in the passenger seat yields nothing. Putting the TPS in a sock with the ignition on, then spinning the TPS around in the sock gives me a flat tire message. I doubt the tube thing would work, or else I would have gotten a flat message while they were in the car.
My shop charged $25 total to dismount and remount with TPS, and that's in 2 parts. Would have been $20/tire if I had it done at the same time. Even the expensive shops only wanted $35/tire. Why spend the cost of 4 TPS to defeat the system when you could have a working system for another ~$150?
Old Oct 20, 2009 | 10:23 PM
westez's Avatar
westez
How hard is it to push the reset button????
Old Oct 20, 2009 | 11:39 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Evidently extremely.
