[Z06] Bilsteins
Old Oct 20, 2009 | 08:49 AM
Z06 Pack's Avatar
Z06 Pack
Default Bilsteins
How much do they improve ride quality after lowering? I plan on lowered my Z as far as I can on stock bolts, and possibly getting longer bolts if I don't think it's low enough after that. Just wanted to get opinions on whether or not the bilsteins are neccesary. $330.00 seems like it would probably be worth it. TIA
Old Oct 20, 2009 | 04:46 PM
1SHADYZ's Avatar
1SHADYZ
I have the Bilstein Sport Shocks and it's really night and day. I had stock shocks when I cut the front bushings and it was real rough. This time when I changed to Bilstein I removed the front bolts and it's outstanding. Even my girl, who doesn't notice anything even said it was a big change
Old Oct 21, 2009 | 08:06 AM
1SHADYZ's Avatar
1SHADYZ
By the way... I got mine from Ebay for $290 Shipped
Old Oct 21, 2009 | 08:34 AM
iLLuZionZ's Avatar
iLLuZionZ
^ how was the install and they work ok with stock springs??
Old Oct 21, 2009 | 09:00 AM
Z06 Pack's Avatar
Z06 Pack
Yes, they work with stock springs.
Old Oct 22, 2009 | 11:56 AM
HiVoltge's Avatar
HiVoltge
St. Jude Donor '08
Bilstein sport shocks are slightly shorter than the stock Z06 shocks and work better on lowered cars...
Old Oct 22, 2009 | 01:49 PM
Z06 Pack's Avatar
Z06 Pack
I knew that, I was just wondering if the difference in ride quality was really worth it.
Old Oct 22, 2009 | 04:11 PM
tomlink's Avatar
tomlink
1SHADYZ - Which eBay vendor did you use for the shock purchase?
Old Oct 22, 2009 | 06:34 PM
1SHADYZ's Avatar
1SHADYZ
I can't find what seller it was on Ebay, Im sorry about that I searched everywhere. Shock Installation - http://fuzzydiceracing.com/test.htm
Old Oct 23, 2009 | 05:07 PM
tomlink's Avatar
tomlink
Thanks anyway. The cheapest I could find on eBay was $313/set but almost everyone else is in the $330 range.
So you really noticed the difference between stock and the Bilsteins?
Old Oct 23, 2009 | 11:10 PM
Rockit.Eddie's Avatar
Rockit.Eddie
Default rough ride
Is the rougher ride with the car lowered because of the stock shocks bottoming? I have an 04 Z Are the Bilsteins shorter than my shocks?
How much shorter?
Thanks,
Rockit Eddie
Old Oct 24, 2009 | 01:07 AM
1SHADYZ's Avatar
1SHADYZ
No problem. Yeah, I couldn't find cheaper either for ya. $313 still pretty good price.
Yeah, it definately gives it a much better ride. They are stiffer shocks so you do feel the bumps but not as rough, it's more of a firm/solid ride. I was really shocked with the outcome. Great upgrade!!
Old Oct 24, 2009 | 01:23 AM
1SHADYZ's Avatar
1SHADYZ
Im sure thats part of it but Im not definately sure about that 1. My guess is the stock shocks are more looser for comfort for the stock height, once you lower the car more then an inch the shocks get really bouncy and rough, no more comfort. The Bilsteins Sports are alot stiffer and they can handle lowered cars b/c of it's stiffness. They are shorter then stock shocks, not that much but I guess it helps though... http://www.2phast.com/Corvette/bilstein06.jpg
Make sure they are Sports not HD b/c they will bottom out!!!
How much shorter?
Thanks,
Rockit Eddie
To Bilsteins
