[Z06] burning smell?
Old Oct 21, 2009 | 08:05 PM
Never Late's Avatar
Never Late
Default burning smell?
I just got my car back today from having the valve springs installed, and in my driveway after some spirited driving, i smelled a burning smell..Id like to think i can drive standard by now since ive been doing it in all of my cars for 8 years haha...i was wondering if its anything to do with the new valve springs and the material curing? i checked my oil levels, as well as clutch fluid and i do not really know what it possibly could be..Tip it didnt do it before the valve spring install unless its just grease etc burning off..any suggestions? oil temp was around 220 today after driving
Never Late's Avatar
Never Late
also coolant temps were around 215
Old Oct 21, 2009 | 09:21 PM
TXGS507's Avatar
TXGS507
When you say a "burning" smell.. does it smell like oil or coolant? Does it drive differently? changing the VS should not have those symptoms.. Did a reputable shop do the work? could they have taken the car on a spirited drive...? More info please...
Old Oct 21, 2009 | 09:24 PM
Never Late's Avatar
Never Late
No spirited drive it was a good shop and good family friend, it was hard to say it just smelled like a burning smell, im not truly sure...but it was after i drove it for a while and i smelled it w hile i was turning the car around in my driveway.
Old Oct 21, 2009 | 09:33 PM
The BreeZe's Avatar
The BreeZe
The shop may have splashed some motor oil or other lubricant during the valve work down onto the exhaust manifold and your cooking it off. Should go away in a drive or two.
Old Oct 22, 2009 | 06:31 AM
Never Late's Avatar
Never Late
Yeah thats what i am ultimately thinking is causing the smell, as it def smells like grease/oil is burning off its not a sweet smell as coolant would be i know what thatwould smell like. I shall see if it ends up going away.
Old Oct 22, 2009 | 09:12 AM
FLHX06's Avatar
FLHX06
Mine puts off a smell like this after some spirited driving as well. I cut through an industrial complex to get to my house so there are a couple of roads where you can get on it a little right before I get home. Once I pull in the garage I can smell a slight burning smell but it I notice it more near the back of the car so I thought it was the brakes.
Old Oct 22, 2009 | 09:59 AM
James92's Avatar
James92
probably oil on the exhaust manifolds which can easily happen when you pull valve covers.
Old Oct 22, 2009 | 11:02 AM
TXGS507's Avatar
TXGS507
I concurr...
To burning smell?
