Car Bubble - Pros/Cons?
Old Oct 22, 2009 | 03:43 PM
c5goodlife's Avatar
c5goodlife
St. Jude Donor '11
Default Car Bubble - Pros/Cons?
Anyone have any good / bad experiences with a car bubble cover over winter? I'm in Chicago so was thinking about it for the winter months. For those guys that use it -- do you put your vette up on lifts to prevent flat spots on the tires? Any other pointers or do most of you stay away from the whole car bubble thing?
Old Oct 22, 2009 | 03:58 PM
itzza427's Avatar
itzza427
Never used a bubble,but if you have a nice garage,,seems like a bit of overkill !! As far as tires go,,there have been several post about that and according to most (including tire company recommendations) that all is needed is to inflate to about 40 psi will prevent problems. Seems a bubble would interfere with keeping a float charger (like a Ctech) attached. Just some thoughts!!
Old Oct 22, 2009 | 04:07 PM
87SAM's Avatar
87SAM
If you are intending to use it outside, don’t bother. A friend tried one and with half inch of wet snow the bubble was squished and laying on the car.
I suppose inside it might help keep the mice out.
Old Oct 22, 2009 | 06:10 PM
I store my car every year - have never put it up on jack stands. I just put a piece of old carpet under each wheel, add a little air pressure, put some StaBil in the gas, change the oil, hook up a battery tender and then put a nice car cover over the car to keep the dust off.
Have not had any experience with the car bubble - might be a good idea if you have critters that get into your garage.
dougbfresh's Avatar
dougbfresh
I've kept all mine in the garage on the battery tender only all winter, I start every couple of weeks and let things get up to temp-that's it. If it's DRY outside I even run it around the neighborhood a couple of times over the winter to keep the gas fresh I top it off while I'm out. Never had a problem in 20+ years of Vette ownership.
Old Oct 22, 2009 | 08:15 PM
tigers123's Avatar
tigers123
Same way I do my motorcycle over the winter.
Old Oct 23, 2009 | 01:39 AM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
Why wouldn't mice just chew through the bubble to nest in your car?
Old Oct 23, 2009 | 06:37 AM
AU N EGL's Avatar
AU N EGL
normal car cover in a garage. Little stay built in the fuel & a battery tender
Old Oct 23, 2009 | 12:22 PM
Shirl's Avatar
Shirl
2025 C8 of the Year Finalist - Modified
2021 C7 of the Year Finalist - Unmodified
Con: Someone could POP it!!
Old Oct 23, 2009 | 04:24 PM
Jims2001's Avatar
Jims2001
I have had one for three years now and love it. There is alot of condensation in my garage and it keeps it off the Vette. with the air that is circulated through the bubble. I roll out the mat, drive the car on to it, take the battery out and turn it on. Blows up in a few mintues. I have it in there from the first or middle of Nov. to the begining of April. Not a single problem. It also protects the car if something falls against it like a shovel or broom. One of the best things I ever bought for my Vette. I just keep my battery in the house for the winter.
Old Oct 24, 2009 | 12:02 PM
Jims2001's Avatar
Jims2001
Let me know if you have any questions.
Old Oct 24, 2009 | 02:35 PM
4theboy's Avatar
4theboy
You won't be able to get your car up on jackstands once it is inside. Just overinflate the tires and you won't have any problems.
Old Oct 25, 2009 | 10:10 AM
Jims2001's Avatar
Jims2001
You could put the car on stands before you inflate the bubble, if you wanted.
Old Mar 12, 2010 | 03:24 PM
robbyd831's Avatar
robbyd831
To Car Bubble - Pros/Cons?
