[Z06] Reverse....Mine pops out, common??
Old Oct 23, 2009 | 06:54 PM
QSZOH6's Avatar
QSZOH6
Default Reverse....Mine pops out, common??
Since the day I bought my Z the original said, " always keep your hand on the shifter in reverse because it pops out of gear when the car is cold". This thing always pops out of reverse no matter if the car is warm or cold. As soon as I dont apply pressure the the shifter it will pop out. I just wanted to see if this was common or not. Not too big of a deal as the car will stay in reverse with forward pressure applied.
Old Oct 23, 2009 | 07:53 PM
z06sicz's Avatar
z06sicz
Should not "pop out" in any gear. Kinda basic but make sure you have it FULLY engaged. Mine takes some "force" to fully engage into reverse.
Old Oct 23, 2009 | 07:57 PM
z060-0's Avatar
z060-0
Mine is also tuff to put in reverse. Have to make sure it's all the way in, or it will pop out.
Old Oct 23, 2009 | 08:20 PM
TXGS507's Avatar
TXGS507
Mine has NEVER popped out of gear.. Mine slides right in...
Old Oct 23, 2009 | 08:29 PM
BUBBAS 01Z06's Avatar
BUBBAS 01Z06
Not common.....
Mine started doing this as well a year ago....
Would go into gear without any problem but would pop at any time under load going in reverse...
Turns out it was a syncros problem !
Easy fix while the new motor is going in
Old Oct 23, 2009 | 09:49 PM
wallifishrmn's Avatar
wallifishrmn
My 71 popped out of first gear. Was told most common is second--but either way had transmission rebuilt--the syncros were bad and needed to be replaced. Agree with Bubbas
Old Oct 23, 2009 | 10:36 PM
QSZOH6's Avatar
QSZOH6
Yep, I always make sure the car is fully engaged in reverse. As soon as a load is applied without forward pressure it will pop out. I figured it was a syncro problem, just not ready to drop the trans just yet. All other gears are fine though.
To Reverse....Mine pops out, common??
