Started the cleanup...
Oct 26, 2009 | 11:22 PM
So I started the cleanup of a recently purchased set of CCW's last night. This was about 20 minutes of work while talking to a friend (not really concentrating on the wheel). Left side is what it cleaned up to. Right side was what they looked like.
Oct 26, 2009 | 11:26 PM
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
Quote:
Originally Posted by
Lancejoker
Good job on your part! Prior owner should be flogged!
Keep up the effort, Those wheels are worth it!
Oct 26, 2009 | 11:34 PM
Nah,he's a great guy. Just didn't clean up the barrels. No biggie.
Oct 26, 2009 | 11:50 PM
What did you use to clean it with?
Oct 26, 2009 | 11:59 PM
Car wash soap,water and a bunch of rags(t-shirts)
Oct 27, 2009 | 12:19 AM
Lancejoker
Take your word for him. Once you get them clean,,,,several coats of Zaino will make keeping the barrels clean easier!
Oct 27, 2009 | 07:02 AM
Should I just use Z-CS or something else?
Oct 27, 2009 | 11:54 AM
It will be some hard work, but those should look great when you're finished. Post up the end results when you're done.
Oct 27, 2009 | 12:04 PM
I don't mind putting in the hard work. Especially considering what I paid for them.
Oct 27, 2009 | 10:27 PM
Yeah can't wait to see them all cleaned up and on your vette.
Oct 27, 2009 | 11:03 PM
It looks like you're doing a good job!
Oct 28, 2009 | 01:02 AM
Probably going to take me a while to get them cleaned,polished,sealed,have TPMS mounted in them and have them mounted and balanced on the car. I'm in no rush though. I'll try to post pictures as I go.
Oct 28, 2009 | 07:31 AM
Wow those barrels are really dirty and I use bling master to clean mine and it is much eaiser than how you are doing it and the shine is also good
Oct 28, 2009 | 09:52 AM
From: Wylie TX --> Less is More, except under the hood !
Get the following once you clean the dirt off...
Works amazing on my CCW wheels !
1.) Adam's Metal Polish
2.) Mothers Power Cone (put on your power drill. low speed)
Oct 28, 2009 | 09:59 AM
Keep rubbing they will look like new when you are thru one of the great pluses with a bare aluminum wheel
Oct 28, 2009 | 03:54 PM
I saw the cone but was considering the Powerball mini. I think I may end up buying the cone though.
Oct 28, 2009 | 04:47 PM
2018 C5 of Year Finalist
Lancejoker
What's the advantage of the cone vs. the powerball?
Oct 28, 2009 | 05:07 PM
MSG C5
Very close to the same I think, but you can cover a wider area with the cone on its side. Especially easy in the wheel drum area. The pointed part of the cone is great getting into the tight spots too. I have not used the mini ball but I personally think the cone would work better for our wheels. Just my opinion though. I like using the Cone that I got.
It cleaned up really well too, and I just hang it up to dry in my garage for next time.
toque
Oct 28, 2009 | 06:27 PM
Where did you find the cone at?
Oct 28, 2009 | 06:34 PM
Lancejoker
O'reilly's Auto parts
http://www.oreillyauto.com/site/c/de...PartType=C0209
I think various auto places should carry them though.
Toque
