Grinding sound
Old Oct 28, 2009 | 12:00 PM
perrypro's Avatar
perrypro
4th Gear
Default Grinding sound
Has anyone experienced a grinding sound , seems every time Im in ,like, a parking lot backing out , or turning at a slow rate of speed, an aweful grinding sound appears to be comming from the rear of the car. when I accelerate then it goes away.
Then the other problem is my turn signals work when they want to
Please help with this
Old Oct 28, 2009 | 01:20 PM
Aerovette's Avatar
Aerovette
Need gear lube additive.
Old Oct 28, 2009 | 01:24 PM
Bill Vett's Avatar
Bill Vett
How many miles, last rear fluid change, did you just replace the rear brakes?????
Old Oct 28, 2009 | 05:39 PM
corvettepete's Avatar
corvettepete
I had something like that on my '99 coupe at around 30K miles. Heard grinding coming from the rear when turning real slow. Was fine at speed. I had the fluid changed in my differential. It went away.
To Grinding sound
