Which Supsension Mods??
Old Oct 31, 2009 | 12:58 PM
Dans99C5's Avatar
Dans99C5
Default Which Supsension Mods??
ok, i have a stock 99 a4 vette. i want to work on the suspension first since i have 90k miles. i want to get brand new c6 z06 shocks and possibly c6 z51 swaybars later down the road, but i came across a deal on here for 04 zo6 shocks, springs, and swaybars with 50k miles for $360. i think its too good of a deal to pass up. which direction do you think i should go. i also plan on lowering it on stock bolts as soon as i get home from overseas. thanks, Dan.
Old Oct 31, 2009 | 01:05 PM
vette.mix's Avatar
vette.mix
I purchased C6 ZO6 shocks (5K) for a little over 100 on ebay and C5 Z51 swaybars for 50, not sure how much the springs are but you may want to look around. I havn't installed them yet so I can't comment on the handling
Old Oct 31, 2009 | 01:09 PM
n8dogg's Avatar
n8dogg
Lets start with what your plans with the car are. Autocross, track, street spirited driving? I think C6 Z06 shocks are a little over kill. Why brand new? You can find great deals all the time of used suspension stuff. Is money a factor? LG just put out a great package deal of coil overs and sway bars. If money is a factor I would look into used C5 Z06 stuff, or pick up C6 Z51 stuff here and there. You can get front and rear sways from a C6 Z51 for about 100 a piece brand new!
Figure out what your plans are with the car and build off of that
Old Oct 31, 2009 | 04:23 PM
00 Rooster's Avatar
00 Rooster
St. Jude Donor '08
I have upgraded to c6 z51 bars-got them used. When my shocks go, I will get new c6 z06 shocks. they seem to be a very popular mod with the c5 crowd and I have yet to hear anything bad about the upgrade.
personally, I do not see the advantage of adding 50k mile shocks. to me they have too many miles but it is your cash.
there is a chart of sway bar sizes which may help your decision-you will have to search for it.
the deal you are looking at is pretty good but for a few hundred more, you could do the c6 gear (minus the springs) and have a lot more life in your parts and better parts imho.
either way, good luck and let us know what you decide
Old Oct 31, 2009 | 06:57 PM
tlc0706's Avatar
tlc0706
50K is a lot of miles on shocks
Old Nov 1, 2009 | 04:07 AM
Dans99C5's Avatar
Dans99C5
first things first, i plan on keeping this car on the street and take it down the 1/4 mile every once and a while. i like to do some corner carving. i was kind of thinking 50k miles was a bit much, so im glad yall brought that up. i think i might just get some c6 z06 shocks and some c6 z51 bars, and they dont have to be new. thanks for the input folks.
Old Nov 1, 2009 | 05:27 AM
double-oh-coupe's Avatar
double-oh-coupe
I'd go with coilovers ... good luck with whatever you decide!
Old Nov 1, 2009 | 06:12 AM
clif's Avatar
clif
St. Jude Donor '09-'10
I have a 99, and replace my F45 shocks and tired leaf springs with Pfadt Adjestable Coilovers. I also swapped my stock sway bars for the Pfadt Street sway bars. My car handles awesome now.
Old Nov 1, 2009 | 07:15 AM
Dans99C5's Avatar
Dans99C5
whats the big advantage with the coilovers?
Old Nov 1, 2009 | 08:47 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Both those selections are great!
I have C6 Z51 Sway Bars and I have the C5 Z51 Shocks - I will be doing thr C6 Z06 shock eventually!
Thanks,Matt
Old Nov 1, 2009 | 10:02 AM
n8dogg's Avatar
n8dogg
Coil overs help keep suspension movement at one wheel. You can also adjust ride height and balance the car equally at all 4 corners. Some ppl argue the coil springs are more responsive than the mono leaf.
Old Nov 1, 2009 | 10:42 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
I would not buy shocks with 50k on them to start with, and it this is mostly a street Vette with little spirited driving, the C6Z shocks will be fine with C6 Z51 bars. On our C6 I have C6 Z51 bars and Koni FSD shocks and like the setup for a daily driven non track car, my C5 is setup a little different, but this Vette sees different driving
Old Nov 1, 2009 | 05:39 PM
Sabre34's Avatar
Sabre34
Moderator
St. Jude Donor '06 thru '26
Old Nov 2, 2009 | 01:27 AM
Dans99C5's Avatar
Dans99C5
ok folks, i just bought c6 z06 shocks and c6 z51 bars w/ metal endlinks from gene culley yesterday. i cant wait to put them on when i get home. thanks for yalls help, Dan.
Old Nov 2, 2009 | 11:10 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
Congrats those parts are a perfect setup for a street Vette
Old Nov 2, 2009 | 11:44 AM
WKMCD's Avatar
WKMCD
Good choice. Down the road you can pickup a set of C5 Z06 springs for even more improvement.
Old Nov 2, 2009 | 11:45 AM
Humy's Avatar
Humy
are you installing your sway bars and shocks urself? ro are you taking to a shop? I would like to know what the shop charges you for the install
To Which Supsension Mods??
Dans99C5's Avatar
Dans99C5
i was thinking about doing that. do you think they would help out that much more than the stock springs?
Old Nov 2, 2009 | 11:47 AM
Dans99C5's Avatar
Dans99C5
i plan on doing the sway bars myself, but i will probably take it to a shop for the shocks. or hell, i'll be tight on time when i get home so i might have em do it all. either way i will let u know. but i dont get home for another couple weeks...im working in africa
Old Nov 2, 2009 | 11:49 AM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
If anyone has any questions at all about Coil Overs and set up please let me know.
__________________
Home of the Fastest Supercharged C5 8.4 @ 158mph
Home of the Fastest Supercharged IRS GTO 9.0@ 155
Home of the Fastest Supercharged C6 9.7 @ 143mph
Proud Sponsor of the ECS Corvette Challenge
http://www.corvettechallenge.info
609-752-0321
