not using TPS. Turn warning light off?
Old Nov 5, 2009 | 02:20 PM
PostShawn's Avatar
PostShawn
Default not using TPS. Turn warning light off?
If I am not using Tire Pressure Sensors in my current wheel setup is there an easy way to disable the warning message so it doesn't come on every time I turn on the car?
Shawn
Old Nov 5, 2009 | 06:27 PM
Oldvetter's Avatar
Oldvetter
Originally Posted by 8VETTE7
On 2001 and newer C5's you can turn it off.
On the 1997 - 2000 cars it cannot be turned off.
So, for your 1999, that is a NO.
Old Nov 5, 2009 | 06:38 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Only occurs on startup though..annoying but just hit reset
Old Nov 5, 2009 | 08:01 PM
Indy's Avatar
Indy
Yep...they changed it in 2001 with the introduction of the Z06, because they run non run-flat tires...Indy
Old Nov 5, 2009 | 11:01 PM
PostShawn's Avatar
PostShawn
I thought there was no way on a 1999 to do so. Thanks.
I do have the TPS but the tires are already mounted without them so I was just wondering if I have to have them remounted to put them in or if I can just say screw it.
Old Nov 5, 2009 | 11:42 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
If it were me I would install the TPS, It is nice to know if you have a tire going down, It could save you a real headache.
jmo
Bill
To not using TPS. Turn warning light off?
