Im going to check and most likely clean my clutch fluid tomorrow as i felt my pedal tonight being slow to return. Ive read a few of the posts on how to do it etc and i know how to perform it and i already have everything i need. My question is, when i suck out the dirty clutch fluid and put in newer clean fluid can i leave the rubber fitting out and cap off while i pump the pedal? or will this suck air and cause an airlock in the system?
I had asked a similar question in the past. From what I saw and did it made no difference if the rubber diaphragm was in or out. The system will not suck air if it is left out. That said, I consider Ranger to be the expert in this area. He told me that the diaphragm must be there for his method to work correctly.
Why would you want to leave out the rubber bladder?
It also servers to seal the cap. If you pump the fluid without the gasket, most likely you will get fluid leaks down the side of the reservoir.
I am not sure what you think you are saving by trying to leave it out?
If you ever watched the fluid in the reservoir when the pedal is being pumped, you will also notice that the fluid can spray up in the reservoir on the return stroke.
Leaving the bladder out and/or the cap off.....not a good idea.
not trying to save anything really, i just feel its easier to do the swap if you dont have to keep taking the cap and rubber piece out. and that is what i was looking for, if its going to spray and what not then i will def leave it in as it is before i pump the clutch. Just wanted this piece of info. thanks though
If I remember right, Ranger said that to do his protocol correctly on a C5, you must drive the car for a few miles for the new fluid to "mix in" with the old fluid. I believe he said it doesn't work to just sit in your driveway and pump the clutch pedal as shown in his video. Therefore you must have the cap and rubber piece installed to avoid leaking fluid from the reservoir. That is how I did it on my car, and it worked perfectly. It did take a few weeks for mine to clear up though.
I was under the impression that you just pump the clutch about 30 times to circulate the fluid. If the fluid is still dark, extract, refill and then repeat the clutch pumping process until the fluid is clear.
you can pump all you want with the cap and diaphram off...fluid wont move...I always bleed without the cap on
Also, doing a full bleed from the slave works even better! It always feels like I have a new clutch after I do the bleed (twice a year usually). Even after swapping the fluid from the reservoir multiple times, it's amazing how dark and dirty the fluid is that comes out of the slave during a full bleed.
Definitely try the Ranger fluid swap method first, but if you're still not happy with the way the clutch pedal feels, try doing a full bleed at the slave.
I saw Ranger's video and that's how I did it.
The following is a response I got from Ranger about changing the fluid in my clutch.
Originally Posted by Ranger
Is it correct you are driving the car between changes?
Unlike the C6, the C5 hydraulics don't self mix well with just top-to-bottom pedal pumps. Car needs to be driven to mix new and old fluids to scour the crud out and up to the reservoir.
Youre not doin it right or wrong cap on or cap off with the fluid swap method...the guys telling you its wrong to do it cap off was what i was killing
When i was stock clutch...I removed the h pipe and tunnel plate and reached the slave bleeder and bled from there...now i have a remote bleeder and do it that way...but you dont have to swap often if the reservoir remains clean...assuming your system is circulating
I just did a couple of friend's cars this weekend, and as soon as they started to pump the clutch, the reservoir turned dark, so you should not have to actually drive the car to circulate the fluid.
Mine was not too dirty, so I just change mine, drive it a week or so, and change it again if it is dark. Mine stays fairly clean now, so I don't have to replace the fluid but every 5 or 6 months.
I usually notice that my brake fluid is also starting to get dark, so I just change them both.
Do you have a remote bleeder attached to the slave? If not, how do you get to it to bleed it? I was under the impression that it is damn near impossible to get to the slave to bleed the darn thing, and that is why Ranger's method is the only real alternative, short of pulling the tranny and installing the remote bleeder.
Any tips on how to get to the slave to bleed it would be greatly appreciated.
Guys,I'm sorry for the silly question..Its just that am wondering,According to Ranger the Dark fluid in the reservoir is caused by the Clutch dust getting in the system..
But how does this happen ?? how does the Clutch dust get into the Hydraulic system..
I suck mine 15th of each month (date I got the car). Cap off pump, no issues. I can't tell any difference in my clutch but it had been changed and I'm keeping after it. Each change, the fluid is somewhat darker, so good move.
I too wonder how the dust gets into the fluid. I saw a demo tape and it seemed to indicate the dust enters slave where the shaft operating the clutch at the slave exits the slave; must be ultra-fine stuff. Quite the phenom but swapping out via Ranger can only help, no cost and time involved when you think about it.
The fluid in question is "hydroscopic" which means it will absorb moisture from the air. The less exposure to the open air the better!! Keep the cap ON as much as possible!!
It's brake fluid or a close variation of brake fluid, so yes it absorbs moisture. Keep the cap on if you're concerned about the fluid absorbing any moisture. The same goes for the new brake fluid as well. I'm not sure about the actual "shelf life" is after the seal on a new bottle of fluid, but it'll collect moisture too over time even with the cap on tight.
It's not that big of a deal to bleed it from the slave. You do have to take off the exhaust midsection and the tunnel plate, but that's it. I've gotten to where I can do it myself by using a small pole to hold the pedal down all the way. I push the pedal down, put the stick in, then use the electric seat to push it all the way down and hold it. Then I can get underneath and bleed, then tighten and repeat that process. About 6-10 bleed cycles gets nice clean fluid to come out of the slave. The pedal feels amazing and brand new after it's all done.
Ranger's method is great for those that don't want to go through that much work (and it's necessary for basic fluid maintenance). But if you're pedal still feels squishy and the fluid stays dirty, try flushing from the slave.
Ive been reading this post and im trying to figure out how to bleed from the clutch slave cylinder.Is there some type of device i can buy from the auto part store and how is it done.I have 80,000 miles and i really never paid attention to the fluid until i realized it was dark black and almost empty.I know its part of routine maintenance but im not to familar with it.Also the synchros in my tranny have all been replaced but ive been told my pilot bearing is gone but i dont believe the dealer as i think they were trying to rob me.I believe some how there is a leak and my system needs new fluid because i get a grinding noise when shifting at times and i believe my slave must have air because if i pump it a few times it shifts smooth which leads me to believe i just need to bleed it and replace the fluid.Any help would be appreciated!
