[Z06] Recall Refused
Old Nov 10, 2009 | 10:36 AM
MarkHZ06's Avatar
MarkHZ06
2nd Gear
Default Recall Refused
Today I went to my local dealer regarding recall GMP06-029-05081 (electronic column lock system). they refused to honor the recall and said I could pay $450.00 for a replacement lock assembly. Called GM Customer Service at 800-222-1020 and they would not reverse the dealership decision. My '02 Z06 displays "remove key,wait 10 seconds,retry". If I do not my cars stearing locks up and the fuel shuts off, creating the precise senario the recall is designed to prevent. Any ideas on how to get GM to pony up and back up their recall?
Old Nov 10, 2009 | 10:52 AM
bumble-z's Avatar
bumble-z
GM, will not pony up one red cent for a deceased recall. Fix your problem once and for all. Order a column lock bypass unit from Corvettes of Dallas and easily installs from start to finnish in approximately one hour. Your car is very close to a decade old! Good luck.
Old Nov 10, 2009 | 05:10 PM
stock z06's Avatar
stock z06
did my column lock bypass after having the same issues you had over a year ago. after the install zero problems now!
ed
Old Nov 10, 2009 | 05:35 PM
Vette_Minded's Avatar
Vette_Minded
Just bought my 04 Z06 this last weekend and took it to the dealership today for inspection. When they ran the VIN the reacall showed up (which I already knew and had already discussed with them) they ordered the part/s and said we'll call you when it comes in.
I wasn't having any issues though.
Old Nov 10, 2009 | 08:12 PM
LO PHAT's Avatar
LO PHAT
I would get it out of there fast...
Part of the recall is the fuel cut-off programming ("flash") as a safety measure if the steering column should happen to lock while driving. If your car has never had any of the column lock recalls done (there were three of them as I recall), don't let the dealer mess with it. Install a column lock bypass kit, and be done with it.
LO PHAT
Old Nov 10, 2009 | 08:55 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Hoping to never have to deal with this problem, I bought the bypass unit from Corvettes of Houston and put it in my car. So far all has been good. I wound up installing two that particular day. My buddy talked me into buying the bypass module and we did mine first so I could learn. Then we did his. I drive mine every day and so far, this is one problem I have not had happen, knock on woood.
Old Nov 10, 2009 | 09:48 PM
bumble-z's Avatar
bumble-z
LO PHAT
I Super Agree with you. Don't let them do the work. Get your car out of there, like yesterday. Order the column lock bypass unit. Install it your self. It's easy to do, and it has a proven track record of doing away with the lockout problem.
Old Nov 10, 2009 | 11:15 PM
kerryt1's Avatar
kerryt1
I also bought a bypass from Corvettes of Houston as a preventative measure. Nary a problem here.
Old Nov 14, 2009 | 11:11 AM
Corvettes of Dallas's Avatar
Corvettes of Dallas
Default Clb at corvettes of dallas
We have then in stock ready to go out--- PLEASE call Todd or Mitch and we will get you back on the road for $49.95 plus shipping.
Todd
Old Nov 14, 2009 | 06:02 PM
Vette_Minded
LO PHAT
Well I'm confused? The dealer told me they have parts on order and will call me when they come in. So they are replacing something not just reprogramming.
Old Nov 15, 2009 | 08:57 AM
LO PHAT's Avatar
LO PHAT
That is correct. However, part of the recall is the flash of your car's computer. From the factory, there was no fuel cut-off programming for a column lock issue. When the recall is performed that programming is added. No dealership can install the harness (2nd recall) or remove the lock plate (3rd recall) without also flashing the car's computer. That is per GM.
Do some research on these forums. After having the recall performed, several members have reported their car's fuel being cut-off even though the steering column was not locked.
Unless your car has already had an earlier column lock recall done (in which case its computer would already be flashed), stay away from the dealership! You'll be one of the lucky ones if you can simply install a column lock bypass kit.
LO PHAT
Old Nov 15, 2009 | 10:01 AM
Vette_Minded
would I be OK if I tell them not to program the computer? I have a pretty good relationship with the dealership and they will listen to me. If they won't I'll look at the by pass.
Old Nov 15, 2009 | 12:49 PM
wildwall's Avatar
wildwall
If you want this problem to be resolved, the only fix is the CLB. You have to do it before it is a problem, because the solenoid has to be in the unlock position to install the module. All the factory fixes will eventually fail and leave you in the same position. The column lock will fail at some point. C5 owners bury their heads in the sand on this isuue, and we see these help posts every week, month after month, year after year. No excuses. THE COLUMN LOCK BYPASS MODULE IS A MANDATORY MOD!
Old Nov 15, 2009 | 12:55 PM
wildwall's Avatar
wildwall
The way it works is with the solenoid unlocked, you unplug the plug from the solenoid and plug it into the bypass module. The solenoid is now permanently unlocked. When you turn the key, the computer gets a signal from the bypass module that tells the computer everything is fine. It's beauty is in it's simplicity. I read about this problem before I got the car and I installed it the first week I owned it.
Old Nov 15, 2009 | 03:19 PM
ZeeOSix's Avatar
ZeeOSix
I didn't think a safety recall had an expiration date on it.
Did GM put an expiration date on this recall? The column lock recall is safely related ... no?
I agree ... put a column lock bypass in the car and fix it yourself. Many have had the GM fix and problems still existed after the recall fix with some owners.
Old Nov 15, 2009 | 03:27 PM
wildwall's Avatar
wildwall
That is pretty crappy of GM to not fix it. I have an Audi and a VW that my kids drive. They are both 2001's. I am not the original owner of either vehicle. In the past few weeks I have received recall notices for both vehicles for the ignition coils. They will replace them for free or reimburse me if I alreday had them changed. I think that's impressive.
Old Nov 15, 2009 | 04:36 PM
jwight's Avatar
jwight
Cruise-In I Veteran
Cruise-In II Veteran
St. Jude Donor '08-'09-'10
Just to recap, this recall is still open on the NHTSA site safercar.gov: http://www-odi.nhtsa.dot.gov/recalls/results.cfm
Summary:
IN 2001, GENERAL MOTORS (GM) ISSUED CUSTOMER SERVICE CAMPAIGNS 1044 AND 1044A TO ADDRESS A CONDITION WHERE THE STEERING COLUMN WOULD FAIL TO UNLOCK DURING THE INITIAL KEY-IN AND START-UP IN CERTAIN MY 1998-2000 CORVETTE VEHICLES. HOWEVER, ODI CONTINUED TO RECEIVE COMPLAINTS CONCERNING STEERING COLUMN LOCKUP ON CORVETTE VEHICLES. AS A RESULT, PE02-054 WAS OPENED AND LATER UPGRADED TO EA02-031 FOR MY 1997-2001 SUBJECT VEHICLES. ODI'S ANALYSIS IDENTIFIED CONCERNS WITH POST-REPAIR FAILURES IN VEHICLES SERVICED THROUGH THE CAMPAIGNS, AS WELL AS, FAILURES IN MY 1997-2003 SUBJECT VEHICLES NOT INCLUDED IN THE CAMPAIGNS. (NOTE: THE MANUFACTURER FAILURE DATA ABOVE IS LIMITED TO MY 1997-2003 VEHICLES THROUGH 10/17/2003.) ON FEBRUARY 6, 2004, GM NOTIFIED NHTSA OF A SAFETY DEFECT IN MY 1997-2004 CORVETTE VEHCLES EQUIPPED WITH MANUAL TRANSMISSIONS AND MY 1997-2000 CORVETTE VEHICLES WITH AUTOMATIC TRANSMISSIONS. THE NOTIFICATION STATED THAT IF THE VOLTAGE AT THE POWERTRAIN CONTROL MODULE (PCM), WHICH WAS DESIGNED TO SHUT DOWN THE FUEL SUPPLY WHEN THE STEERING COLUMN FAILED TO UNLOCK AND THE CUSTOMER TRIED TO DRIVE THE VEHICLE, IS LOW OR INTERRUPTED, THE FUEL SHUT OFF MAY NOT OCCUR. AS A RESULT, THE CUSTOMER COULD DRIVE THE VEHICLE WHILE THE STEERING COLUMN WAS LOCKED CAUSING THE DRIVER TO LOSE STEERING CONTROL AND POSSIBLY CRASH WITHOUT WARNING. GM WILL INSTRUCT OWNERS TO BRING THEIR VEHICLES TO A DEALER TO HAVE THE PCM REPROGRAMMED FOR MANUAL TRANSMISSION VEHICLES AND THE ELECTRIC COLUMN LOCK DISABLED FOR AUTOMATIC TRANSMISSION VEHICLES. ODI WILL MONITOR THE EFFECTIVENESS OF THE REMEDY IN THE MANUAL TRANSMISSION VEHICLES AND TAKE FURTHER ACTION IF WARRANTED.
To Recall Refused
Old Nov 15, 2009 | 06:46 PM
DD04C5's Avatar
DD04C5
Check your battery.Weak battery will also cause this error code.Seen it many times.
Old Nov 15, 2009 | 06:53 PM
Shylor's Avatar
Shylor
Todd
How about a group buy discount?
Old Nov 15, 2009 | 08:20 PM
LO PHAT's Avatar
LO PHAT
1) I highly doubt you could pull that off. Others have tried this and failed. Some have even have had the recall done without their permission (their cars where at the dealership for other services and the dealer simply performed the open recall work). Even if the service advisor were to agree to it, the technician will still likely follow the exact steps outlined in the GM service bulletin protocol.
2) As others have said, none of the recalls actually solve the problem. They may keep the steering wheel from locking for safety while driving, but it will not prevent you from one day being stranded when the solenoid freezes and your car won't start.
It just isn't worth it. Get a column lock bypass kit.
LO PHAT
