New Plugs
Old Nov 11, 2009 | 12:21 PM
Marbleye's Avatar
Marbleye
5th Gear
Default New Plugs
My first time here. I just bought a '03 Zo6 and am about to change the plugs (they're original). Any tips on the best plug to buy or any problems I might encounter? I hear #7 is a bear.
Old Nov 11, 2009 | 12:36 PM
C5Aggie03's Avatar
C5Aggie03
I've always used NGK TR55's on all my LS1 cars. I would also recommend the MSD wires. They look good and get the job done.
Plug #7 is tricky. Get an extension and move most of the stuff in the way to get to this plug easier. Good luck.
Old Nov 11, 2009 | 12:45 PM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi Marbleye -
http://www.iammoon.com/c5tech/c5_plugs.htm
Looks best in Internet Explorer.
best regards -
mqqn
Old Nov 11, 2009 | 01:24 PM
DeeGee's Avatar
DeeGee
Absolutely spot on although I went for GMPP Reds
Old Nov 11, 2009 | 03:06 PM
johnson-rod's Avatar
johnson-rod
Iridiums and red wires from Gene at GMPartsHouse. #7 is not that bad.
Old Nov 11, 2009 | 03:31 PM
I'd recommend AC Delco Iridiums and the GMPP red wires - get them from Gene at gmpartshouse.com.
Old Nov 11, 2009 | 09:12 PM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
Thanks for the referrals. I certainly appreciate it.
||--Genuine GM Tune-Up Items--||
12495519 – GMPP red spark plug wire set – 60.00
12621258 – GM AC Delco Iridium spark plugs – 6.47 each
10287788 – 97 & 98 fuel filter – 12.96
19239926 – 99 – 04 fuel filter/pressure regulator – 81.06
25042562 – 97 – 04 air filter – 11.86
Old Nov 11, 2009 | 10:11 PM
Marbleye's Avatar
Marbleye
5th Gear
Originally Posted by mqqn
Hi Marbleye -
best regards -
mqqn
Thanks. This is extremely helpful and reassuring to someone like me who is mechanically challenged! What a great tool the forum is!
Old Nov 11, 2009 | 10:48 PM
itzza427's Avatar
itzza427
Delco Iridiums here too and all I can say is !!
Old Nov 11, 2009 | 11:15 PM
mqqn's Avatar
mqqn
Cruise-In V Veteran
Hi Marbleye - Glad you think it will help you, that's why I put that page together.
Good luck!
best regards -
mqqn
Old Nov 12, 2009 | 07:45 AM
RSchleder's Avatar
RSchleder
Buy a spark plug wrench that has a flexible knuckle on the end and it will make your job MUCH easier. Don't be afraid to tackle it, #7 just takes a little patience and be sure to pull the vacuum tube off the brake booster and move it to the side I ordered my plugs and GM performance wires from Gene, you can't beat his prices and service.
Old Nov 12, 2009 | 03:15 PM
teebee's Avatar
teebee
2021 C6 of the Year Winner - Unmodified
That's what I did...thanks Gene.
Old Nov 12, 2009 | 04:18 PM
csexton's Avatar
csexton
Worked well for me
Chuck
Old Nov 14, 2009 | 10:53 AM
Gene Culley
You guys are the best. Thanks for the support
Old Nov 14, 2009 | 11:17 AM
Bullet Proof's Avatar
Bullet Proof
I just installed the NGK TR55 and went with magnecore KV85comp 8.5 wires......and #7 will be a blood sacrafice!!!
To New Plugs
