[Z06] Why are vette rims two different sizes?
Old Nov 12, 2009 | 06:53 PM
MillertimeZ06's Avatar
MillertimeZ06
Default Why are vette rims two different sizes?
Just wondering is there a reason front rims are a different size than rears? Or is it just for looks?
Old Nov 12, 2009 | 09:32 PM
hattitude's Avatar
hattitude
You also need the rears to be taller than the fronts for active handling to work.........
Old Nov 14, 2009 | 08:08 AM
David426's Avatar
David426
Its a Conspiracy between GM and the Tire Industry.. They figured with different size rims we would not be able to rotate our tires, forcing us to buy new rear tires at an accelerated rate, thus stimulating the tire industry
Old Nov 14, 2009 | 08:14 AM
AU N EGL's Avatar
AU N EGL
Aesthetics. Looks better, or so the designers thought
Old Nov 14, 2009 | 08:33 AM
Solofast's Avatar
Solofast
A very good friend was one of the ride and handling engineers on the C5. When the car was in development we were discussing the front tire size and rim width that they were working on (we were both with GM at the time) and he indicated that they needed to skinny down the front tires to make aerodynamic performance numbers.
BTW he was confident that the car would be fine with narrower rims on the front and that it would be as fast with the with 255's as the older C4's (Z07 C4's had 275's up front) and we all know that wasn't the case.
Once they went with different width rims and tires on the front, it wasn't any stretch to go to different diameters. Remember that they went with skinny rims on the front of late model base suspension C4's, so as early 1993 you couldn't rotate tires on the base suspension car although Z07 cars had a square setup.
Old Nov 14, 2009 | 10:33 AM
MillertimeZ06
Interesting! Someday I may want to buy new rims and tires and the advantage of the same size rim is obviously now I can rotate and not feed into the corporate tire companies ploy to sell more tires! I just didnt know if it was anything other than just a looks thing or had a actual performance gains.
Old Nov 14, 2009 | 11:09 AM
AU N EGL's Avatar
AU N EGL
many of us run 18" on all four corners. Some 19" or even 17" all around
And some ppl even the same wheels and tire combos on all four corners. ( I did for a year)
Challenge with four identical wheel tire combos come from AH / TC. If you turn AH/TC Off there are no problems.
Ideally the rear tire should be 1/2" taller then the front to have no AH /TC issures
Most performance tires are directional tires. so moving from left to right, is not really a good idea.
For performance gains, if that is your objective stick with 18s or 17s on all four corners. This is mostly a weight issue. Large rims and tires weigh quite a bit. And Rotating wt from tire/wheel combos are the death of performance.
For each one pound removed from rotating weight, ~ 6.5 lbs removed of static weight our of the car.
each 100 lbs out of your car, or 12.5 lbs less wheel weight is equivalent gaining 10 rwhp more.
Good Luck
HTH a bit
Old Nov 14, 2009 | 11:17 AM
redrose's Avatar
redrose
there are a bunch of good reasons to have larger rear tires on a rwd RACE car...for street use, maybe even a hazard.
Old Nov 14, 2009 | 02:33 PM
MillertimeZ06
Ouch so same size tires will cause issues with active handling but doesnt really affect performance. This actually alters my original idea of same size rims. I use active handling to keep me from getting out of control. Even today pulling out in traffic with cold tires the traction control kept things from possibly going bad. Thanks for the info guys.
Old Nov 14, 2009 | 03:03 PM
AU N EGL's Avatar
AU N EGL
Yes and No
I ran 18x25.5/11.5 on all four corners. It handled fantastily. Grip was great. Yes these were Good Year G19s Slicks. R450 compound.
best handling my car had. But must turn off AH/TC too allow the car to drive and handle the best.
But 18x12 rear and 18x10 front with Nitto NT555
Nitto NT555 305/35ZR-18 101Y B & 285/35ZR-18 97Y B
Old Nov 15, 2009 | 11:25 AM
MillertimeZ06
This is great info. My car is a street car only. I think if I do decide to go with rims and tires It will be 18"front and 19" 11 rears. Forgestar f14 rims has just offered an 18" 9.5 for front but is limited in availability. I really appreciate the info because Its an expensive decision and I would have been unhappy with having to turn off my tc/ah all the time.
To Why are vette rims two different sizes?
